Results 1 to 10 of 10
    Established Member Two Rings pologk04's Avatar
    Sep 12 2008
    2001 A4 2.8Q Sport
    South Pasadena, CA
    Is this the engine oil drain plug?
    This picture was taken in the front of the car from the driver's side under the fender looking toward passenger side of my 2001 A4 2.8 Quattro. I'm curious if the bolt in the center of the picture is the drain plug for the engine oil. And I'm planning on using Mobil 1 10W30 synthetic. Should that be alright?
    2001 2.8Q Sport.
    Established Member Two Rings newtonc2001A4V6's Avatar
    Jan 23 2006
    2011 Audi A4 2.0T, 2004 Lexus RX330, 1977 MG-B
    Colorado
    Re: Is this the engine oil drain plug?
    Quote Originally Posted by pologk04 View Post
    Yes that is it.
    I prefer Castrol Syntec 0W30; it meets VW502 and ACEA A3, which your owner's manual calls for.
    Does Mobil 1 10W30 meet either? The 10W30 high mileage does, is that the version you got? Either way, it probably doesn't matter as Mobil 1 is a very good oil. YMMV.
    Sep 12 2008
    2001 A4 2.8Q Sport
    South Pasadena, CA
    Quote Originally Posted by newtonc2001A4V6 View Post
    Yes that is it.
    Mobil 1 10W30 does not meet either of these. It meets ACEA A1/B1 and A5/B5. Do you think its a big deal?
    2001 2.8Q Sport.
    Jan 23 2006
    Colorado
    If you change it <or any quality oil, esp synthetic> regularly, I doubt it.
    I also use the OEM Mann oil filter, but I am a bit paranoid.
    I only have 110K on my 2001 V6 A4, so it is just getting broken in.
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    thats the drain, use oem filter, i use 5w40 snythetic
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Sep 12 2008
    2001 A4 2.8Q Sport
    South Pasadena, CA
    is it that important to use the OEM filter? I already bought a FRAM. I guess I could get another if i need to.
    2001 2.8Q Sport.
    Jan 07 2007
    fram's arent great in my opinion, but if you change it AT 3000it should be fine. if you already have it might as well use it. just get an oem or mann next time. prob same price
    Sep 12 2008
    2001 A4 2.8Q Sport
    South Pasadena, CA
    Will do next time. Jeez, theres a lot of details to worry about in these cars. I've had the car for about 4 months and I learn something new like this every time I pop the hood!
    2001 2.8Q Sport.
    Aug 13 2008
    Indiana
    people just listen to shit... 10w30 will not hurt the car but it wont start as easy on cold mornings. In the summer its almost the same as running 5w30.
    -Nic
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    I personally have had issues in past Audi's using a fram filter. It did not have the correct valve in it and in turn did not keep the oil pressure up. Mobil 1 or OEM filter seems to be the best. I bought a box of OEM from GermanAutoParts.com. I also use 5w-40 but I'm not sure if the V6 uses a different weight. Just keep an eye open for your oil light if you put the fram filter on as if it pops on it's probably for pressure reasons.
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
