Results 1 to 6 of 6
Thread: Timing Belt Q?
    Registered Member Three Rings seanriv's Avatar
    Jan 07 2008
    2001 Audi Allroad, 2015 Mini Cooper
    San Francisco,CA
    Timing Belt Q?
    hey guys,
    In the middle of my tbelt job and have a couple quetins?
    -What happens if you move the crank counter clockwise while the tbelt is still on?
    -Doing cam and crank seals, but dont have the cam and crank lock tool. How do I do this without the special tool? I cannot find the DIY anywhere.
    Thanks guys!
    -Sean
    Senior Member Three Rings jpcallmotor's Avatar
    Jan 11 2009
    B5 A4 1.8T
    Chicago
    Re: Timing Belt Q?
    DO NOT move it backwards! Keep it at TDC. If you haven't taken off the belt yet, you can still rotate the motor by hand, just make sure you are back at TDC when you take off the belt.
    Jan 07 2008
    San Francisco,CA
    Re: Timing Belt Q?
    I moved it backwards (counter) when the belt was still on, and then clockwise to TDC. That ok? Just wanted to know if it was bad to rotate the crank counter and clockwise while the belt is still on. I know not to move it while the belt is off.
    Jan 07 2008
    San Francisco,CA
    Re: Timing Belt Q?
    Please. Anyone?
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Re: Timing Belt Q?
    your fine, as long as you put it back to TDC before removing the belt, MAKE SURE YOU ARE AT TDC
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Timing Belt Q?
    theres an awesome chance that you will never get the crank bolt out, and on top of that you should always have a new crank bolt when you do it anyway... is it actually leaking? You can use the crank bolt to hold the tension to break the cam gear loose
    - Clint
