Results 1 to 16 of 16
Thread: Getting Ecodes
    Registered Member Two Rings
    Jan 08 2009
    AUDI B6 DG A4 3.0 Quattro
    SB Socal
    Getting Ecodes
    My 02 B6 A4 seems to have hologen housings (Part number 8E0 941 030 F), but I don't know my bulbs are whether D1s or D2s. All I found from my headlights is that part number above. Anyway, I decided to get Ecodes(a complete housing kit including OEM xenon bulbs & ballasts), but I have to know what fits to mine. D1s type or D2s? If I replace the both housings, should I still care about the type of bulbs? I am thinking of getting D2s type Xenon Ecodes. Also, the OEM HID kit costing $1,400 from ECS tuning is reasonable? Or, is there another way to get HID kit cheaper?
    One more question. To replace license plate lights to the white, what should I do?
    Sep 02 2005
    Montreal
    Re: Getting Ecodes
    Quote Originally Posted by tesmike View Post
    Neither. H7.
    All ECodes will be D1S.
    A pair of 5GL ballasts with a pair of genuine Philips 4300K D1S bulbs should not cost more than 400$
    Buy white bulbs.
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Re: Getting Ecodes
    The D1S bulb has the ballast attached to the bottom of the bulb. It looks like the bulb is sitting on a pedestal. The D2S bulb does not. If you already have halogen bulbs then you don't have either one as they are both HID bulbs.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Sep 13 2008
    Western Chicago Burbs
    Re: Getting Ecodes
    i have so bad news for you. valeo, which is the company that makes the ecodes s supposedly having problems with their molds. i ordererd ecodes a month ago and stll havent received them. they are on backorder. there is no way to get ecodes right now so you might want to consider doing the joey mod. and the bulbs you have are d1s.
    Sep 13 2008
    Re: Getting Ecodes
    Quote Originally Posted by Undisputed View Post
    wrong. that is the starter. it still has an external balast
    Jun 29 2008
    Re: Getting Ecodes
    Quote Originally Posted by B6JoeA4 View Post
    You're correct. Sorry bout that. That's what I get when my fingers type and are not completely connected to my brain.
    -Damon-
    Jan 08 2009
    SB Socal
    Re: Getting Ecodes
    Wow. Thank you so much. From my understanding, it is better to keep my halogen housings and set a pair of 5GL ballasts with a pair of genuine Philips 4300K D1S bulbs, isn't it? If so, how can I get a pair of ballasts and the bulbs? Are those on Ebay or ECS?
    Sep 02 2005
    Montreal
    Re: Getting Ecodes
    You can keep your halogen housings, as long as you swap the halogen projector for a HID projector, before you install the D1S bulbs/ballasts:
    http://cgi.ebay.com/ebaymotors/ws/eB...m=380092415423
    Jan 08 2009
    SB Socal
    Re: Getting Ecodes
    Okay. Just bought the HID projectors from your link. Then, what's next?
    Sep 02 2005
    Montreal
    Re: Getting Ecodes
    Once you swap them with your halogen projectors, you can install the OEM HID components that fit directly into your stock housings:
    http://www.hidconcept.com/Kits-valeo-d1s.html
    You could also buy a cheaper, aftermarket HID kit (from DDM Tuning for example), but since 99% of those only come with D2S bulbs, you could use a screw to secure a D2S bulb in a D1S bulb holder, like so:
    http://www.audizine.com/forum/showpo...6&postcount=19
    The big disadvantage with aftermarket ballasts though is that they don't fit directly into the housing like the OEM ones do.
    Jan 08 2009
    SB Socal
    Re: Getting Ecodes
    Thank you sooooooooooo muchhhhhh, Mxrz! Surely I don't want to go with a ghetto mod at risk. I am so glad that you saved me from this mess. I really appreciate. If I buy that Valeo OEM HID kit, can I DIY alone without any problems, like a light warning, malfuntions from aftermarket ones?
    Jan 08 2009
    SB Socal
    Re: Getting Ecodes
    Just bought the OEM HID kit from HIDCONCEPT. Thank you so much. Is there anything to know when I install them? So I will have HID projectors and OEM HID kit soon on my Halogen housings. How about headlight adjustment? After the set up, Do I have to take the car to the dealership to correct it?
    Sep 02 2005
    Montreal
    Re: Getting Ecodes
    You can do everything yourself, it's pretty straight forward, you shouldn't get any warning lights. Adjustment is manual, just like with halogens.
    Jan 08 2009
    SB Socal
    Re: Getting Ecodes
    Okay. How about buying white bulbs for the license plate lights? Is there a specific type of bulbs that I have to buy?
    Oct 16 2006
    Naperville
    Re: Getting Ecodes
    you guys are going about this ecode thing all wrong. you should be looking on ebay.de for them and find out if the seller is willing to ship internationally. i got my bixenon ecodes for 250 shipped plus 15o for my ballast and bulbs... all used of course, but for that price who cares.
    Sep 02 2005
    Montreal
    Re: Getting Ecodes
    If you want white LEDs, these will work:
    14.5v 39mm Fuse Style LEDs
    http://42draftdesigns.com/categories.../leds_fuse.htm
