Results 1 to 8 of 8
    Mar 15 2008
    Formerly CT, now Bay Area
    Same springs, different ride height?
    So while waiting around Freddie's shop today I met a fellow AZer by the name of AudiRob. Turns out he has the same exact spring/shock setup as me (H&R Sport/Bilstein) yet he's about half an inch lower in the back!
    We're both FWD, both have the same shocks, both the same springs, both dolphin grey :P, and I've already put about 3 months worth of driving on my suspension, so why are my rears so high?
    Here's a picture of my car after my suspension install - unfortunately the rear is still about that height while AudiRob's has practically no gap.
    Senior Member Two Rings Tacoman_Si's Avatar
    May 27 2007
    2004 b6 USP
    lake stevens
    Re: Same springs, different ride height?
    maybe he took out the rubber o-rings the stock springs sits on.. weird.
    2004 white 1.8T USP 35% tint// CF B-pillars//Milltek exhaust//milltek hi flow cat//Turbo Smart DV//19 inch VMR 714's//2500k yellow fogs//Clear Corner mod//B6 LED tails//RS4 sway//podi w/boost gauge//koni coilovers//AVIC D3 BT & IPOD//Alpine amp//Kenwood 12" DVC
    Dec 06 2007
    u sure he did not have H&R race springs?
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    if you have bilstein sport struts, i know that those raised my car a little but going from tein spring/oem base strut combo to adding those on. maybe you and rob have differences in H&R springs or bilstein struts, they make different types.
    Mar 15 2008
    Both H&R Sport and Bilstein Sport
    Veteran Member Four Rings yoogene83's Avatar
    Apr 27 2004
    2017 Pacifica Limited / 2014 BMW M5
    Seoul
    sure he doesn't have a subwoofer and box in the trunk?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I have a zero finger gap in the rear but I am quattro. But still your gap should be lower
    -Sami-
    Senior Member Three Rings jaynyce's Avatar
    Nov 12 2005
    05 Audi A4 Quattro USP
    take a look in his trunk maybe he has something in it or did his springs sag a bit?
