Results 1 to 12 of 12
    Oct 11 2008
    2002 Audi A4 1.8T Tip
    Connecticut
    Exclamation Rear Caliper Possibilities
    So my rear calipers are shot on my car. I was wondering what type of rear calipers I can possibly use for my 02 1.8T I have 9.3in rotors and didn't know if I can use another models calipers for my car. Suggestions?
    Dec 06 2007
    Re: Rear Caliper Possibilities
    u can go for a B7 rear brake setup like i am larger discs and larger calipers and upgrade ur front as well.
    -Kirk
    BetaAlphaTau Member #58
    Sep 13 2008
    Western Chicago Burbs
    how about some used b5 s4 front and rear. that would be a nice setup
    Dec 06 2007
    ^^b7 a4 rear is better
    -Kirk
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    RS4
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    just to expand on this inquiry. what setup would require less work to bolt onto a B6?
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    In Limbo Two Rings
    Jan 17 2009
    Nor*Cal
    Any 8E chassis setup will directly bolt on
    Oct 11 2008
    Connecticut
    can the b5 s4, b7 a4 and the 8E setups work with a 16in wheel.
    Oct 11 2008
    Connecticut
    are the b7 rear rotors and calipers a direct bolt on?
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    i dont think the b5s4 rears will work on our car, i know the b6s4 will for sure
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Senior Member Three Rings FourRingsB6's Avatar
    Oct 07 2008
    2005 A4(HIS), 1999 Jetta(HERS)
    Lancaster, PA
    From what i got out of the original post you're not looking to upgrade the front as well. If that is the case then stay away from b7 rears. You would be 288 front and rear at that point.
    Stretched, poked, and slammed.
    Buncha motorcycles
    Memphis, TN
    s4/rs4 gives you the best, i know the the s4s are 300mm vented rotors...
    APR Stage 2/AWE Intake
