Results 1 to 4 of 4
    Sep 21 2008
    05 B6 Sedan; 04 B6 Avant
    Derry, NH
    Kinda Urgent. Coolant reservoir almost empty .......
    And I'm 300miles away from home, and no dealerships are still open to source G12 from
    Will it be safe to just add enough distilled water in the reservoir just to be safe until I get back home tomorrow and top off with G12? I'm in South Jersey today (Toms River) and will take the trek back home tomorrow.
    Thanks in advance
    2oo5 B6 Sedan Q | Dolphin Gray | SE | Platinum interior | 1.8T | Tiptronic
    2oo4 B6 Avant Q | Silver | Platinum interior | 1.8T | Tiptronic
    Sep 13 2008
    Western Chicago Burbs
    Re: Kinda Urgent. Coolant reservoir almost empty .......
    how much do you need to add. if you just need to fill the resivor, i think you will be fine
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    It's really cold weather around here as of late and you're heading into even colder weather. If you need a lot of coolant, I wouldn't fill up with water. It will be fine when you're running it but if you let it sit overnight in this weather it's going to freeze and you have to get it out of there ASAP if it's going to be mostly water. What I mean to say is if you are running on mostly water you have to come up with another option or promise to drain it before it has a chance to freeze.
    Does anyone think he is better off adding Prestone Extended Life instead of water until he can pick up the G12 and replace?
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Sep 13 2008
    if he adds a non compatible fluid, its gong to gum up
