Results 1 to 6 of 6
    Veteran Member Three Rings audizz a4's Avatar
    Jan 04 2009
    2002 audi b6 1.8t 5spd DG
    grayslake
    parking cable times 2?
    2002 audi a4 quattro cables froze up dealer said i need to buy 2 of them as there is one for each side? is this true. ive been having the same problem as many of u and have just been not using my ebrake since it gets hung up and sometimes i get the break buring smell out back. i like to be able to use my ebrake but would the problem fix itself once the warm weather rolls around?
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Re: parking cable times 2?
    Quote Originally Posted by audizz a4 View Post
    Yeah, there are two cables. I had both of them pop off twice about a month ago. I just quit using the ebrake when it's cold outside. It's not worth the hassle. You should be able to use it without any problems once it gets warmer outside.
    Oct 29 2005
    10speed
    San Francisco, CA
    it SUCKS to put the cables back on the hooks
    - Clint
    Oct 16 2006
    Naperville
    my ebrake handle is totally soft right now so not sure whats going on with it. its still hooked on the rear calipers. but for a short time i was in the same boat as you guys, and then it led to this.
    Veteran Member Three Rings 02B6's Avatar
    Nov 05 2007
    Toronto, Canada
    Quote Originally Posted by manguyen View Post
    being soft would mean the rear brake is still engagded. Not sure if you know how to disengadge manually, but it can be dont with a stick threw the rear rim.
    2002 (B6) 1.8TQM...H&R - S4 Spoiler - 6k HID - open cone filter - Forge Splitter - avic d3 - podi/SW
    Jan 04 2009
    grayslake
    can u point me in the direction on how to do this disengadgement haha
