I have the following codes. Basically went to lunch car drove fine, came back car acts like it has no boost. Car starts, idles and drive fine it just has no boost, I don't have a boost gauge, it just is very sluggish. If I unplug the MAF it does not change at all, tried unplugging the N75 also no difference. Any thoughts, did my Ecu take a Crap. All other functions work, Cruise, ESP ABS. Really need some help.
VCDS Version: Release 805.1
Data version: 20081223
Saturday,17,January,2009,15:20:30:06561
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAULC68E22A225246 Mileage: 171390km/106496miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 F HW: 8E0 909 018
Component: 1.8L R4/5VT G 0001
Coding: 0016701
Shop #: WSC 63351 000 00000
8 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - Implausible Signal - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 004 - No Signal/Communication - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 008 - Implausible Signal - Intermittent
16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
P0139 - 004 - No Signal/Communication - Intermittent
16712 - Knock Sensor 1 (G61): Signal too High
P0328 - 001 - Upper Limit Exceeded - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 002 - Lower Limit Exceeded - Intermittent
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 004 - No Signal/Communication - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0100
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04275
Shop #: WSC 06435
2 Faults Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
