Results 1 to 3 of 3
    Senior Member Three Rings lonestar22's Avatar
    Aug 19 2008
    DFW
    CV axles vs Lowering
    as some know i lowered the S4 recently and its pretty low. i drove on it two days before getting an alignment and when i had it up in the air i noticed grease on the inner passenger side cv axle boot cover. i figured its bad no problem ill get another one. but then today i was test fitting my wheels when i noticed the rear driver side outer axle now has a minor leak. but its not torn just coming out from where i meets the axle. is this a common problem when lowering your car too much? am i eventually going to have to replace all four axles just because i lowered my car? will it happen again eventually at this ride height? any help will do, thanks.
    SGM 330i 6MT/RD PLATE LIGHTS/RES DELETE
    STAGE 1 B5 S4, CAN YOU SAY SLAMMED?
    Sep 05 2007
    Wood Dale, IL/Schaumburg, IL
    Re: CV axles vs Lowering
    If it just barely started leaking you can get away with replacing just the boots and the clamps. If it's ripped wide open and there is contamination then you need to remove the axles, clean the CV joints and then replace the boots or just install remanufactured (or new) axles.
    -Mike
    Current: 2009 Black Ford Mustang GT - Stock
    Sold: 2000 Audi S4 Quattro Sedan - Light Silver - Stock as hell.
    Sold: 2003 SVT Cobra Mustang - Sonic Blue - Not even CLOSE to stock.
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    when you're lowered it's more likely to happen.
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
