Results 1 to 10 of 10
Thread: Inmotion tuning
    Veteran Member Three Rings audizz a4's Avatar
    Jan 04 2009
    2002 audi b6 1.8t 5spd DG
    grayslake
    Inmotion tuning
    just talked with a rep today
    seemed very knowladgable ok so here we go
    im pretty sure im going to go this route
    he told me theyve got 3 cookie cutter tunes?
    base tune
    stage one
    custom race
    im going to go with the base tune which puts me at 15-16 psi and for an additional 50 im going to have the speed limiter removed and if i choose another 50 to have the rpms raised? if so what should i have it go to? i dont think this is necessary because the k03 falls flat around 4500-5k so i wouldnt need that extra rev?
    i can also pay more to have them push the psi up more but recomends not too because of such a small turbo
    the custom tune consists of exact specs for what i want and unlimeted tuning after the first one, they send me the firmware and cable and i do it off my laptop for $500 i dont kno if im planning on doin a bt so that sounds liek i dont need it
    i have also purchased a forge 007dv
    temp and boost gauges
    anybody have experience with inmotion
    dont bash because there small
    what kinda tune is the big 3 have in comparison? the psi around the same level? rev limiter etc????
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Inmotion tuning
    Go for it...
    Jan 04 2009
    grayslake
    Re: Inmotion tuning
    haha doesnt help me out much.... just bustin ya, anyone have experience with them?
    i ordered the base tune had them remove the speed limiter and rasied the rpms to 7300
    me excited = pppppp
    Jan 04 2009
    grayslake
    Re: Inmotion tuning
    ttt
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Inmotion tuning
    Why would you bump th post after 30 min? Not like it moved but 4 or 5 places. Tune is probably renamed Optican.
    Jan 04 2009
    grayslake
    Re: Inmotion tuning
    because i am trying to make my decision in the next hour or so, i trust u guys but not the attitudes of some. opticon?
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Re: Inmotion tuning
    Revo Stg 1
    utilizes everything factory, except the DV.
    Boost can range anywhere from 16psi - 22 psi on 91 octane gasoline
    the boost curve will spike at 2800-3200 rpm and hold 10-12 psi at redline. That's just the efficiency range of the turbo no matter what software you run.
    Good luck.
    What price are they asking for the tune?
    Post up once you get it done.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Inmotion tuning
    Quote Originally Posted by audizz a4 View Post
    because i am trying to make my decision in the next hour or so, i trust u guys but not the attitudes of some. optican?
    OptiCan, Neuspeed, many other names too...
    The tuning you are interested in is developed in Europe, I did a slight search and found no Audi owners that have tried it (as INmotion), however I do suspect that it is OptiCan based tuning http://www.opticantuning.com/vehicles.asp
    OptiCan tuning is a decent product that was developed in Europe by OBD Tuning GmbH, so it is not specific to US fuel or US spec automobiles, however it works nevertheless.
    Neuspeed sells it for $399
    From what I did see online, INmotion USA appears to have GREAT customer service and are very responsive to customers, the only real complaint I have seen is that they sell stuff for much less on eBay and the prices jump up and down from time to time.
    Jan 04 2009
    grayslake
    Re: Inmotion tuning
    well ill let u guys know weds. wen i get the ecu back
    Active Member Two Rings beefcake's Avatar
    Aug 15 2010
    So how do you like your inmotion tune? Now you can share some feedback with the group.
