Results 1 to 8 of 8
    May 08 2007
    Las Vegas, NV
    rear brakes diy?
    I've searched on here, AW, and audidiy for a writeup on the rear brakes but I can't find anything. I've found numerous ones on the front brakes, so my question is if the rear brakes are, for the most part, similar to replace as the fronts. I say brakes being pads and rotors.
    I'm decently mechanical....should I be able to figure out the rear brakes with the diy for the front brakes?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: rear brakes diy?
    Quote Originally Posted by Ahh Liicks View Post
    For the pads, you're probably gonna want the caliper tool to compress the piston for the rears. You can do it without it but it's much easier with it.
    08 S4- Stock SOLD
    Jun 29 2007
    antioch, Ca
    You could just use a pair of needle nose pliers and push as you turn to depress the calipers. Just put the tips of the pliers in the grooves.
    Veteran Member Three Rings Ianxcom's Avatar
    Jul 30 2008
    Socal/Denver
    I followed this for the rear brake pads and was very helpful. Only thing is when i took the ebrake off the car rolled forward and off that crappy stock jack and landed on the rotor. Thank god I wasnt under the car. Rookie mistake i guess. Put something in front and back of the front wheels.
    http://www.audiworld.com/tech/wheel2.shtml
    Active Member Two Rings quattroSD's Avatar
    Nov 03 2007
    B5 S4
    San Diego
    Quote Originally Posted by Ianxcom View Post
    next time, leave the car in gear. This will limit the car from rolling.
    also, i would probably have left the e-brake off while doing rear pads and/or rotors.
    and yes, most definitely chock the F & R wheels.
    sounds like you got it done ok though...
    C. Murphy
    Drive Fast, Take Chances
    May 08 2007
    Las Vegas, NV
    thanks for the help, ordered brakes from purems.
    will tackle this when they get here
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    got a dumb question....
    is purems selling those rotors individually or in pairs?
    C5, Giac, 2Bennet , UUC, snub, 034, piggies, RS6 SE catback, rear S4 BBK, RNS-E, JHM, darintakes, K&N, forge, samco, rs6 reps, OZ Ultraleggera, phat box, 4.2 blades, clear corners, LED tails, tinted - SOLD
    Rolling on AR 402, H-sports, Milltek Turboback, O.CT tune, LWFW w/RS4, Stoptech ST-40 332mm fitted in stock 17", hyperboost BPV, Quad-xenon
    May 08 2007
    Las Vegas, NV
    i'm pretty sure individually
    I'm goin to call though to make sure, i'll let you know
