Results 1 to 18 of 18
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    3.545 CAPS time tonight...........
    Boost leaks fixed.............check
    Single digit temperatures.................check
    26psi.........................check (allows a more static comparison for me)
    Beat my old 3.79 by .245
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: 3.545 CAPS time tonight...........
    Got your txt man, I just have way to many to reply to at the moment lol
    Sep 24 2005
    always in design
    Quote Originally Posted by 317ssayzarc View Post
    Stay warm in the garage, what you getting into this weekend? What's the dilly with Derek's project?
    I need a larger hotside
    Dec 11 2006
    Boston
    The last time you did your CAPS, did you have the leaks?
    I would imagine the quicker time is do the lower temps.
    Stage 3+ RS6's
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    nice software
    pretty good caps time too
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    What were your temps with your other time. Pretty hard to compare them if the difference in temps was pretty big.
    Sep 24 2005
    always in design
    Quote Originally Posted by deb38 View Post
    I have no idea exactly when the leak started, but odds are it was there in July and was just getting bigger and bigger and bigger. The cold temps are only 50%. Did you see the picture of the coupler with my thumb sticking through it and the heat wrap burned straight through?
    I agree, but the leak was gargantuan and was much more of a factor in my opinion than the 20* temp difference. It was 8* tonight and last time I did a log it was about 28-30* My times were consistently just at 4seconds then, I couldn't beat my 3.79 (done when it was 58*) time to save my life even when in the high 20's with low humidity.
    Dec 14 2005
    8*? t-shirt weather!
    its -16 here tonight.
    1999 Subaru Outback
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    Caps, I'm guessing that's like Fats for B5 S4s?
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Sep 24 2005
    always in design
    Quote Originally Posted by maxspeed View Post
    It's almost to chilly for a wet T-shirt contest IMO
    Quote Originally Posted by Audi S4 Turbo View Post
    Si We have a database and Maxspeed made a little on the fly calculator for us, but the BAT one is not working propa.
    Mike what was the last one you put down? You need to send Tim and email or I can as him why he didn't put it up.
    Jul 07 2004
    socal
    Quote Originally Posted by bassed View Post
    Here you go. I figure its right around 3.73. This was done on the uphill track at Fontana in warm temps during the BOTI event.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Nice time. You an use Alt+Prt Sc so you don't have to crop the image.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jul 07 2004
    socal
    Ian, now get out to the track and lets see what it runs in the 1/4.
    BTW do you have a log of your block 115? If you do you should graph the actual boost reading vs the rpm. Unless you have a wide band that is also logging boost vs rpm.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Nice time Ian! Was that with or without meth?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by GetBoosted84 View Post
    Last I knew, or saw, he was a meth-head.
    Looks good Ian. I'm still glad you didn't sell that car.
    Jan 25 2006
    A4 2.0T
    MD
    I think my last CAPS run was somewhere around 3.8xxxxx.
    Lets see some track times Ian.
    Sep 24 2005
    always in design
    Quote Originally Posted by Don Supreme View Post
    It's January and 20*. I want to hop back on ASP's dyno in the next week or so to see just how much it improved with the re-working of my charge pipe. If I do it when it's in the 20's it should be fairly similar atmospheric conditions.
    If a strip was open to do a pass or 2, I would.
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    x2!!!
    The harder I practice, the luckier I get.
    - Gary Player
