Results 1 to 6 of 6
    Registered Member Two Rings
    Jun 23 2008
    Orange, CT
    high mileage maintenance
    hey guys
    My 2.8 is approaching 130,000, i have'nt done anything to the car maintenance wise, just performance wise. what am i going to be looking at as far as stuff that's going to break in the next 20,000 thousand miles. Also what should i deffinatley replace because of safety, if anything? Also if you can add in approximate prices.
    Thanks in advance
    Dec 19 2007
    1988 Mercedes 300E, 2008 Triumph Speed Triple
    Colonie NY
    Re: high mileage maintenance
    The short list assuming you mean literally done nothing but oil changes..
    1)Timing Belt, water pump, thermostat, belt tensioner, coolant change.
    $3-400 self $9-1100 stealership
    2)Brake pads, rotors,fluid change,replace lines
    3)Oil, air filter
    4)Rear wheel bearing
    5)Tie rods
    6)Dash display
    If you search you will find more I am sure
    Veteran Member Three Rings oldblu's Avatar
    Jan 01 2008
    Budd Lake, NJ
    performance?? Like what? hook me up with what you know
    --Silver 2000 A4 2.8L V6 Quattro
    S4 Bumper. Borbet Type LS Wheels. M3 Replica Spoiler
    Blue! How come there's no ice
    in my lemonade?
    Jun 23 2008
    Orange, CT
    allright well, have the intake mod done with k&n, exhaust, its lowered, new brake rotors and pads at 95,000 along with timing belt job. other then that i wanted to know what i would be looking to replace like wheel bearings, control arms, stuff like that.
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    well with things like tie rods and control arms and bearings... just wait until they wear out to replace them... no use jumping the gun and spending money when you could still get a lot of miles out of the oem parts
    i would only think about doing control arms and tie rod ends if you have some gnarly clunking going on, otherwise you're probably ok. if your timing belt was done at 80k like it should have been, you can probably wait at least another year on that.
    i would do 034 density line mounts... they are not very expensive, you can change them yourself, and they're like a double whammy performance/maintenance upgrade
    {99.5 Avant}
    Jun 23 2008
    Orange, CT
    sounds good man, thanks i am not trying to jump the gun and spend money that i dont have my concern is that i am doing 60 miles a day commuting to school, 30 each way.
    So sometimes i tend to drive the car pretty hard in rush hour trying to get home as fast as i can. It a safety concern for me i dont want to be doing a 100-110 and have something stupid break that i should have fixed, you know what i mean.
