ok so i scanned my a4 using VAG-COM and thang got the VCDS- release scanned the a4 with that and what i got was .........
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 AF HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0001
Coding: 0016701
Shop #: WSC 63351 000 00000
10 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - MIL ON
16685 - Cylinder 1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded - MIL ON
16688 - Cylinder 4: Misfire Detected
P0304 - 002 - Lower Limit Exceeded - MIL ON
16686 - Cylinder 2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded - MIL ON
16687 - Cylinder 3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded - MIL ON
17519 - Oxygen (Lambda) Sensor Regulation: Bank 1: System too Lean
P1111 - 002 - Lower Limit Exceeded - MIL ON
16891 - Idle Control System RPM: Higher than Expected.
P0507 - 001 - Upper Limit Exceeded - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded - MIL ON
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 001 - Upper Limit Exceeded - Intermittent
16712 - Knock Sensor 1 (G61): Signal too High
P0328 - 001 - Upper Limit Exceeded - Intermittent
Readiness: 0000 0000
can anyone help me with this i think the big problem is the 17519 - Oxygen (Lambda) Sensor Regulation
the car has 2 Oxygen Sensors i dont know which one it is help!!!!!!!
