Results 1 to 7 of 7
    May 14 2008
    Huntington, NY
    Timing Belt maintenance
    Hey Guys, I'm getting my timing belt and water pump done just wanted to know if its necessary to get the pulley done also?
    Dec 19 2007
    1988 Mercedes 300E, 2008 Triumph Speed Triple
    Colonie NY
    Re: Timing Belt maintenance
    Its already apart, do it
    Established Member Two Rings Tigu's Avatar
    Sep 05 2008
    a4 MK1, Octavia II
    Hellinn Talsinki
    100% do it!
    May 14 2008
    Huntington, NY
    What's the worse case scenario, if let's say it doesn't get changed out? Not that it won't be, I plan on changing it anyways... just wanted to hear the flipside.
    Sep 05 2008
    a4 MK1, Octavia II
    Hellinn Talsinki
    crash boom bang.
    meaning you will brake the whole head, maybe injure the block as well and youll need a new engine.
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    actually, the worst that happens is the tensioner will give out if not replaced, the timing belt will slip causing the valves to hit the piston and bend. the pistons and short block will be ok, but you will need to either replace the head, replace the valves and lap the valve seats, or upgrade vvt aeb and/or high rpm valvetrain, + optional headwork (3/5/7 -angle valve job, port/polish, oversize).
    once the belt breaks or shears, you will need to replace it again, as well as the bad tensioner and/or pulleys, with additional labor for doing the same job twice. save yourself the grief and pony up the dough.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Active Member One Ring optimusprime72's Avatar
    Aug 23 2008
    B5avant/s5 beast coming soon
    nj/fl
    you should it.. avoid possible problems later on
