Results 1 to 7 of 7
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    New OEM DV 06H 145 710 D - Diaphragm Removed!
    Hey guys,
    we were recently working on a few new vehicles and discovered another rolling change VW/Audi has made. Apparently they have upgraded the Diverter Valve, again, to the new part below. It looks pretty solid from what we can tell and the spring included feels a bit stronger as well. The new part number is 06H 145 710 D. We've seen little to no problems with the OEM G valve, however we'll be testing this new OEM part with all our setups.
    From looking at ETKA it appears this new valve will come standard on all 2.0T's from now on so there may be a few people out there with this part already!
    I just want to point out, we are not selling this part or keeping an inventory of them so I'm sorry, I can't sell you any. If anyone wants to pick one up, check with your local VW parts department to see if they have began stocking the part! Looks like this is going to be a cheap solution for everyone running the early 2.0T DV's!
    Here are the photos!
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Established Member Two Rings D.NGUYEN's Avatar
    Feb 17 2009
    2009 Audi A4 2.0T 6MT
    Re: New OEM DV 06H 145 710 D - Diaphragm Removed!
    does anyone who received their car recently have this DV?
    Veteran Member Four Rings PESAPC's Avatar
    Aug 19 2007
    B7 RS4 + B8 A4 Avant + JEEP SRT8
    I have that in my AVANT ... seen it touched it
    Took delivery in late DEC 2008
    B7 RS4 - JHM R-Clutch/LWFW/CP/Short Shifter + Milltek Exhaust + JHM Piggies&Tune + F/R Brembo BBK + HRE
    B8 AVANT S-Line FMIC + F Brembo BBK + BBS + STaSIS Exhaust + GIAC Tune
    BOTH Ohlins Coilovers + Rear Sway Bars + Michelin PS2 + Tint
    Veteran Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2024 VW Atlas SEL Premium R-Line, 2024 Ford F-150 RCSB
    How can you tell if you have this??? I got my b8 in november 08...
    b_boy
    '23 SQ5 P+
    Sport S, B&O, Nav, Black Optics, Black Nappa, Black Sport Exhaust, Mythos Black, VAG-COM, LED Reverse Lights, IE ECU Tune, CETE
    Tint: 15% F/R, 50% Windshield
    Wheels: Rohana RFX11 Brushed Bronze - 22x10.5 ET32 // Pirelli Scorpion Zero A/S+ 265/35/22
    Aug 19 2007
    Quote Originally Posted by B_Boy View Post
    Only sure way is to unbolt it and look at it ... have fun though cause it ain't easy to get to unless you have car up on a lift.
    Oct 22 2009
    Pittsburgh, PA
    Has anyone used this on a B6? I have a 2004 A4 and may need to replace the DV valve. The connector into the engine is worn, so I have to replace that... it just started running hard at idle and stops, so I ran a VAG-COM. Attached is a photo of the worn area.
    Codes:
    17519 - Oxygen (Lambda) Sensor Regulation: Bank 1: System too Lean
    P1111 - 002 - Lower Limit Exceeded
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 001 - Upper Limit Exceeded
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 008 - Implausible Signal
    16685 - Cylinder 1 Misfire Detected
    P0301 - 008 - Implausible Signal
    16686 - Cylinder 2 Misfire Detected
    P0302 - 008 - Implausible Signal
    16687 - Cylinder 3 Misfire Detected
    P0303 - 008 - Implausible Signal
    16688 - Cylinder 4 Misfire Detected
    P0304 - 008 - Implausible Signal
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    That photo is of a check valve, which is a completely different part.
    The DV does not work on the B6 since it's electronically operated, while the B6 valve is operated by vacuum.
