Results 1 to 3 of 3
    Established Member Two Rings mnsirtee's Avatar
    Aug 19 2007
    los angeles
    transmission clutch problem never heard of
    i recently just changed my clutch. when i turn on the car in neutral, it show 5mph. axle would be turning as well. when i step on my clutch pedal all the way down, it would go back to normal. clutch shifter are normal, no problem engaging and disengage gears. when i removed my tranny, i unscrew the pluges of clutch cylinder instead of removing it completely off the tranny. could my problem be the clutch cylinder?
    97 a4 2.8l manual.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: transmission clutch problem never heard of
    uhh.. kinda hard to get what your saying, BUT basically i am seeing that while in neutral with the clutch pedal not touched your car shows 5mph with the axles turning therefor it moves in neutral? Did you touch your shift linkage at all when doin the clutch?
    Aug 19 2007
    los angeles
    yes, exactly. yes i did touched the shift linkage but put everything back together as it was. i can go into gear like normal, i am just wonder if it was normal for new clutch to be engage like that? in neutral when i rev it, the max i see is 20mph.
