Results 1 to 15 of 15
    New Big Brake Options for your A8 & S8 !
    Rotora has just released a new front BBK for both A8 & S8 in either 14" 2 piece rotor, 6 piston caliper fitment. Or the monster 15" 2 piece rotor 8 piston fitment for extreme applications. This is a complete bolt-on fitment with everything needed for installation included. With caliper color options of red or blue and rotor choices of slotted or drilled/slotted, the kit can be tailored to your taste at no additional cost. Of course, wheel fitment would need to be reviewed at the time of purchase.
    Key Features:
    Rotora billet aluminum alloy 8 piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
    Rotora billet aluminum hat with "floating" disc assembly to reduce heat related stress and unsprung weight.
    Rotora 2 piece vented heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs (380x34mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
    Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
    Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
    Retail priced at just $2425 for the 14" and $3325 on the 15", feel free to contact me for forum pricing, availability, and fitment.
    Jun 04 2009
    atlanta
    Re: New Big Brake Options for your A8 & S8 !
    what is my price for a 2005 a8l for the 14 inch
    Quote Originally Posted by brosco View Post
    You have a PM.
    Senior Member Three Rings vwgti16vt's Avatar
    Mar 02 2008
    87 GTi 16v, 98 M3 Sedan, 98 M3 Convertible, 02 S4 Avant, 09 M3 Sedan, 15 M4, 17 Range
    Scottsdale, Arizona
    Better Brake Option, OEM Plus
    Hello-
    I work at a small race car manufacturing company as an engineer and web designer. I own a D2 A8 as well as a few other Mk2 and Mk3 VW's.
    I recently finished designing a 385mm front brake upgrade kit using all OEM parts with the addition of a CNC machined double sheer caliper bracket that I design and tested in CAD. Much stronger and safer then the single sheer caliper adapters that are currently offered.
    The kit uses a 385mm, 15.1 inches, front rotor and a Porsche Big Red or Audi D2 S8 front caliper.
    I should have the parts machined and available for sale in the next few weeks. All you will really need is my caliper bracket and you can source the rest of the parts directly from manufacturer, web, ebay, etc.
    I will post pictures as soon as I have it installed on my Audi A8
    Please let me know if you guys want any more info.
    B5 S4 Avant has me hooked
    Mar 02 2008
    Scottsdale, Arizona
    Vivid racing-
    I saw on Craigslist here in Arizona that you were hiring a new guy to handle all your website and form sales, make posts and offer new parts.
    Its always tough to bring in a new guy so please don't take this as a bash or anything.
    Let him know that he is adding 1 to many php "[IMG]" tags around your images when he is making your posts that that's why there are an extra open and close tag around all your pictures.
    When you host on Photobucket the links they create already have the open and close tags in them.
    Or use the direct HTML code if you are going to code the "[IMG][/IMG]" by hand
    I appreciate the headsup. I'm actually the one handling the majority of the web/forum sales now.
    I know what you're talking about with the [img] tags; this thread was posted before I took over Audizine, and I haven't gone through and fixed all the threads started by other employees.
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    Do you have a two piece replacement rotor only that can be used with the OE brackets or caliper carriers and and the OE calipers for an S8 (V10) that uses 385 x 36mm rotors?
    I have a friend with an S8 that as gone through two sets of OE rotors and prefers to not upgrade the calipers but only the rotors.
    TIA
    PM sent!
    May 14 2008
    2015 S8; 2020 Q3 Prestige; 2012 Golf R (w/ the six speed...)
    SF Bay Area CA
    Same question here as last one...
    I have the 385mm set up already on a W12--same as S8 basically. Are just the rotors available as a separate part, at what exact diameter (relative to the 385mm stock for this fitment), and at what price?
    Thanks.
    Re: Same question here as last one...
    Quote Originally Posted by MP4.2+6.0 View Post
    Thanks.
    Yes, you can definitely get replacement rotors!
    PM sent with pricing.
    Veteran Member Four Rings TighTT's Avatar
    Feb 21 2006
    Widebody'd avant with AZR 3.0 TTE 950+
    NJ/NYC
    Any BBK's for D2 S8's??
    50% Blood
    50% Sweat
    50% Forced Induction
    Thats 150% motherf*cker.
    Quote Originally Posted by TighTT View Post
    Unfortunately neither Brembo or Rotora offer a BBK for the D2
    Sorry man
    Feb 21 2006
    NJ/NYC
    Quote Originally Posted by vividracing View Post
    Sorry man
    Damn! Seems like MOVIT is the only company that has a kit for us D2'ers.
    50% Blood
    50% Sweat
    Yeah - I'm surprised more aren't offered. It's a big car to slow down quickly.
    Active Member One Ring r8dream's Avatar
    Sep 05 2009
    2000 s8 6speed manual lhd
    london uk
    in the uk www.autops.co.uk also www.amdtechnik.com do rs4/6 365mm discs 8 piston set ups for about £1700, in germany www.ultimot.de have 385mm 06-s8 for d2, www.rs4-bremstechnik.de and www.urquattro.net have 390mm new rs6 setups £2100 or look here http://cgi.ebay.de/Audi-A8-RS6-Brems...d=p3911.c0.m14 all for d2 a8 and s8 ,john
