Rotora has just released a new front BBK for the B8 A5 & S5's in either 14" 2 piece rotor, 6 piston caliper fitment. Or the monster 15" 2 piece rotor 8 piston fitment for extreme applications. This is a complete bolt-on fitment with everything needed for installation included. With caliper color options of red or blue and rotor choices of slotted or drilled/slotted, the kit can be tailored to your taste at no additional cost. Of course, wheel fitment would need to be reviewed at the time of purchase.
Key Features:
Rotora billet aluminum alloy 8 piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
Rotora billet aluminum hat with "floating" disc assembly to reduce heat related stress and unsprung weight.
Rotora 2 piece vented heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs (380x34mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
Retail priced at just $2425 for the 14" and $3325 on the 15", feel free to contact me for forum pricing, availability, and fitment.
[IMG][/IMG]
[IMG][/IMG]
