Results 1 to 7 of 7
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    Question Clearing the headlight error w/o VAG
    Ok so my vag isnt working for some odd reason.. I recently as most of you know started having problems with my E-codes and the aim of the lights.. I took them apart and leveled them equally. Put them in my car, the adjusters equalize them, and then.... the headlight error came on!
    AHHH! I tried to use VAG-COM but the stupid thing kept saying I needed it to be activated/licensed for it to work. So for the time being I removed the fuse so it would do that annoying BEEP and have that icon every time I drive it.. BUT I need to plug that fuse in again so that the lights aren't pointing in the air vs. the floor (where they should be) How can I clear it?
    THANKS!
    - 2016 VW MK7 GTI Performance Pkg. DSG/Nav/Light pkg/cloth seats.
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Feb 27 2008
    Re: Clearing the headlight error w/o VAG
    bump
    Veteran Member Three Rings tatarin's Avatar
    Feb 11 2008
    05 B6 S4 Nogaro 6spd
    deerfield IL
    i have the same issue... has anyone figure out how to clear this with NON activated vagcom cable?
    Mar 27 2005
    The Cold North
    check the wiring harness to make sure it is 100% connected. i had the harness come loose and it thru the 'dipped headlight' on the dash. otherwise you need to find someone that was willing to spend the money on the activated Vag-com software, chanel 55 will allow you to finish resetting everything.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Feb 11 2008
    deerfield IL
    yeah mine is all good my error came on when i attempted to recode the headlights aiming little higher!
    Senior Member Two Rings PTAudi's Avatar
    Oct 05 2008
    Mission Viejo, Ca.
    Sorry trying to understand..how do you re-code your headlights? is this done through a vag-com?
    My lights are aiming low and is throwing a light (circle with a "x" through it) not, the light shown above in the picture.
    Is there a specific code or something?
    Aug 26 2005
    No way around having to reset the auto leveling contoller in basic settings mode with a functional VAG-COM.
