Results 1 to 22 of 22
Thread: HID Help
    Dec 17 2008
    North Bend, Wa
    HID Help
    Just installed my new kit and when i turn my headlights on the bulb will hold out for two minutes than start to flickar and then go out. If i turn the lights off and then turn them back on it will repeat the process. What did i do wrong?
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: HID Help
    You went aftermarket instead of doing it properly.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Dec 17 2008
    North Bend, Wa
    Re: HID Help
    Well than what is the proper way of doing it?
    And my other side light works. Whats up with this one?
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    Re: HID Help
    You might have mounted the Ballast too close to something eles causing this to happen. Where are your ballasts located?
    02 A4 3.0Q6MT
    -chad
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: HID Help
    Quote Originally Posted by bradman View Post
    OEM HID housings, OEM ballast, OEM bulbs.
    Appearance: OEM+
    Dec 17 2008
    North Bend, Wa
    Re: HID Help
    I mounted the ballast on the top right hand side of the headlight. Towards the drivers wheel well. Where is the best place to stick it?
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Re: HID Help
    Check your connections again..... OEM or Aftermarket if its not making a full connection this will happen... Check the connection from the ballast to the bulb...
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    Re: HID Help
    Quote Originally Posted by Tgr_Clw View Post
    money down the drain, money down the drain, and lastly.....money down the drain. There's a reason why the call dealerships, stealerships
    which company did you buy from? Could be your connections, could be faulty equipment (sometimes it happens with VVME HIDs, so i hear). Sounds like faulty equipment to me : /
    Mar 27 2005
    The Cold North
    Re: HID Help
    Quote Originally Posted by forevraudi View Post
    OEM lights are the way to go. They cost a little more but they are designed to work properly. If people just ordered/purchased their cars with OEM HID's people wouldn't have to screw with all these cheapo aftermarket kits that just don't fit or work right.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    Re: HID Help
    and pay an extra 250 dollars while paying my college tution i dont think so
    Joooe Mamma!
    Senior Member Two Rings tank8677's Avatar
    Oct 17 2006
    04 B6 S4, 01 NISSAN XTERRA 4X4
    Houston
    Re: HID Help
    i have mine at the wheel well too and i dont have any problems..switch the "bad" ballest to the other side and see if it does the same thing, if it does that mean you have a bad ballest, if it doesnt then check your connections...good luck!!
    92 EG 12 SEC. ALL MOTOR B18C BUILT CIVIC HATCHBACK--SOLD
    93 EG B18C CIVIC HATCHBACK--SOLD
    94 JDM ACURA LEGEND--TOTALED
    99 MIDNIGHT BLUE ACURA 3.2TL--SOLD
    01 AQUA BLUE NISSAN XTERRA 4X4--UNDER CONSTRUCTION
    02 B6 A4 1.8T--APR SNUB MOUNT/H&R SPRINGS/CC MOD/6000K HID/DE-BADGED/ECS YELLOW FOG BULBS/BLACK RS4 WHEELS/BLACK OUT TRIMS
    08 TOYOTA TUNDRA--3 INCH LIFT AND 33s A/T TIRE.
    04 B6 S4 4.2 V8--DOLPHIN GRAY METALLIC, H&R SPRINGS, 18s BBS L/M, APR SNUB MOUNT.
    Sep 02 2005
    Montreal
    Re: HID Help
    No one is suggesting to get the stuff from the dealer... Were you born yesterday?
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: HID Help
    *ding*
    Appearance: OEM+
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Re: HID Help
    I paid $500 for ecode housing, full set of ballast and new bulbs. Plug and play, works awesome, and are not menace to driving society.
    I will say that geometry of aftermarket output is usually bad, you probably will piss people off. But audi uses projector lens, so it's not that bad.
    After long bitching, I installed HID on my friends jeep. He's so bad, that people on third floor have their rooms lit.
    Feb 06 2008
    03 a4 tip
    CAL, PA
    Re: HID Help
    I have aftermarket HIDs in my joey modded headlights. They are great. Im in college too, so I feel your pain. I mounted mine behind the drivers side headlight and in the passenger side wheel well. Just use zip ties or double sided tape to secure and your good to go. I have been running mine for over a year and no problems and in my opinion they look better than oem. You can look good on a budget, it just takes a little more work. If you still have issues pm me and I can try to help further. GL.
    z
    Mar 20 2008
    south
    Re: HID Help
    Quote Originally Posted by EBG 18T View Post
    he is saying to buy lights from the dealership! hence OEM
    Joooe Mamma!
    Sep 23 2006
    Houston TX
    Re: HID Help
    no. used OEM from classifieds, ebay, etc.
    Mar 27 2005
    The Cold North
    Re: HID Help
    Quote Originally Posted by pa4ul View Post
    there are plenty of other places to buy OEM other than the dealership.
    2020 Chevy AEV ZR2
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    Re: HID Help
    i would check the connection you might have them backwards....i have vvme and i have never had a problem
    211,000 miles
    ||Borla||forge dv||35%||awe||k&n||autobahn hoses||awe smic||ssac||walbro 255||
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    Re: HID Help
    move the ballasts around and check your connections and make sure nothing is crimping the wires. i went aftermarket and have had NO problems with them except at the beginning when the brake light was on but since that day, not one issue. just make sure you plugged everything into the RIGHT slot, and no connections are crimped. :-)
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Veteran Member Three Rings JayStang's Avatar
    Jun 23 2008
    2008 Audi A4 S-Line Ti 2.0T
    Boston, MA
    Re: HID Help
    Quote Originally Posted by T0M3K View Post
    Where'd ya pay $500 w/ everything included?
    Oct 16 2006
    Naperville
    Re: HID Help
    IF you find someone from ebay germany tha will ship to the US, you can typically get a set of ecodes for about 250 shipped (housings)
