so i was putting my coil pack back in and took the head of the hex bolt right of. where can i find replacement bolts and how would you go about getting the bottom of the bolt out?
thanks
because racecar.
"Einstein: Any man who can drive safely while kissing a pretty girl
is simply not giving the kiss the attention it deserves. "
1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
