Results 1 to 6 of 6
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    new suction jet, now my hose is collapsing!
    Ummm,
    So I installed a new suction jet and hose while I was at it and now there is so much suction the hose is collapsing, any ideas?
    At first I thought I installed it backwards but it only goes on one way.
    HELP! Bout to drive 300 miles and don't want my car to die.
    GO KNIGHTS!
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Re: new suction jet, now my hose is collapsing!
    Quote Originally Posted by sloweryucf View Post
    ...so I installed a new suction jet and hose while I was at it and now there is so much suction the hose is collapsing, any ideas?
    WHICH HOSE??? U can cure it temporarily by putting a hose clamp or 2 in the middle of the hose and directly on top of where its trying to collapse. I used 3 on my cheap replacement boost hose.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Veteran Member Three Rings darkstar's Avatar
    Dec 25 2004
    1998 silverado, 1986 c10
    Folsom, CA
    Just glue your old one back together with pastic glue I and many others have done this
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    there may be another issue, since there should not be so much sucction, see if you connected everything well. netter safe than sorry! see if you have maybe a check valve inline near that may be defective or missing.
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Quote Originally Posted by ziggituning View Post
    good call, do some more investigating around the engine bay.
    Feb 21 2008
    Orlando, FL
    I replaced all but one of the check valves. I checked that one though and it was okay. It's the hose coming off the intake manifold running into the suction jet.
    GO KNIGHTS!
