I'm hoping you guys can help me out here...
Yesterday I was installing my fogs and was trying to install the fog light switch (original part from Audi).
I took the switch for the headlight leveler (right word?) to measure where I could tap in to the different wires (+12V, back light etc.) with a multimeter, and I tried to fit the foglight switch just to see if I could figure anything out.. At this point everything was normal and working correctly.
Then I put everything back together the way it was, did not add any cables, and turned the ignition on and flipped the light switch to full. At this point none of the lights in the dash or centre console worked, AND my driving lights went on.
I have no idea what has happened. Was thinking that I had blown a fuse, but how the hell would that make the headlights turn on when I turned on the ignition (normally I'd have to start the engine for them to light up!)?
So does anyone have any good ideas on how to fix this?
