Results 1 to 10 of 10
Thread: Cold S4
    Sep 01 2007
    2000 S4
    Columbus, Ohio
    Cold S4
    I don't know if it was the sub 10 degree weather or what but my car will not fully warm up. The water temp will vary from half way to the half way mark and the second line and the oil gets near or at the first line. This is true even after 30 minutes of driving. Is this normal for cold weather? TIA guys
    Jun 01 2008
    Apopka, FL
    Re: Cold S4
    even at 60-70 degree weater my s4 takes a very long time to warm up completly..however, depending on when it was replaced last, you could try to replace the thermostat with a higher tempreature one to prevent it from opening so soon. using thinner oil helps *alot* as well, espically since it's cold enough there to acutaly be taken advantage of, use a 0-30 in the winter, and 5-40 in the warmer months and you'll notice an improvement as well
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Re: Cold S4
    Its the oil, my grandfather up north uses a light on his porsche, like a heat lamp light, and runs it under the hood onto the oil. Makes the oil not gooey and more like liquid.
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: Cold S4
    Quote Originally Posted by obviouspro View Post
    you need to replace your thermostat
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Re: Cold S4
    Mine took a little longer than normal to warm up today (-7F here), but it does sound like you need to replace the thermostat. It took the oil, seemingly forever, to warm up. And I'm using 0w40.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Cold S4
    Do you actually not have heat inside the car or is it just the gauge that's not coming up to temp?
    08 S4- Stock SOLD
    Jun 01 2008
    Apopka, FL
    Re: Cold S4
    Quote Originally Posted by mholme View Post
    that would be pretty unusual for *both* sensors to go at the same time.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Cold S4
    Quote Originally Posted by blmlozz View Post
    True, but I'm thinkin the oil temp being low could just be a result of the cold as balls temps outside(My oil takes a good bit to warm up now a days too.) and hopefully the low coolant gauge is just a sensor. I'd think thermostat as a worst case scenario versus a 20 dollar sensor.
    08 S4- Stock SOLD
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Re: Cold S4
    yeah, you probably got something wrong with with the thermostat.
    I'm assuming ur in C-bus.
    my car is taking about 7 mins of driving to warm up, oil temps normal and water temps are normal.
    B5 S4 AWE Stage 3 - sold
    Sep 01 2007
    2000 S4
    Columbus, Ohio
    Re: Cold S4
    Thanks guys I figured it was the t-stat so I will check that out. This car is starting to become a pain. Changing the aux water pump with a broken hand was not fun haha. This problem occurred before doing that as well so I know I didn't screw that up. I am driving down to Dallas tomorrow so want to get everything sorted out if possible and I probably won't need the thinner oil down there but I will keep that in mind for the future.
    Raj-Are you selling your car??? And I feel like my car doesn't even warm up in 7 minutes in the summer, hmm.
