Results 1 to 4 of 4
    Jan 01 2009
    Sweden
    audi s3 boost questions PLEASE HELP!!
    hello everybody i have the eurojet dv kit, and the eurojet pcv kit and the vf enginering intake
    I wonder if 17 psi is normal for this and on higer rpms its losses a but down to 13psi is this normal how much sould i boost??
    Cherrs thankfull for answer
    Veteran Member Four Rings littlewhite's Avatar
    PNW Rainy States
    Re: audi s3 boost questions PLEASE HELP!!
    Yes, as it gets higher in RPM the boost falls off/flattens
    Littlewhite
    Veteran Member Four Rings SoFresh's Avatar
    Mar 15 2006
    Seduction Motorsports 1955 Porsche 550 Spyder, Porsche 356 Coupe
    Scottsdale - Palm Springs
    I used to spike at 22 and hold 18, after the eurojet DV kit installation, I spike at 18-20 ish and the boost curve drops fast...
    I've been thinking of loosing the Eurojet setup overall, however I think I just need to purchase the BSH v-twin splitter for my boost tap that should open, close the DV better.
    I had to modifty the Eurojet PCV as well, removed the black thing inside the valve (Joel from Eurojet told me the DV needs that to be done... did it, still nothing)
    I think the pipe from the TB down (larger in size I believe) is whats causeing lower boost levels, and spikes, or it could be the EA pipe thats included in the kit.
    Production Manager - Gunther Werks
    Founder - Seduction Motorsports
    Mar 15 2006
    Relied to your PM
