Results 1 to 20 of 20
    Sep 20 2007
    Harrisburg, PA
    Air bag light in cold weather?
    I noticed my air bag light comes on in cold weather. Once the car warms up it goes away. Has anyone else gotten it? Also, any idea why it may happen and if it signifies anything is wrong with the car? Thanks.
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Re: Air bag light in cold weather?
    mine came on last night.. and stayed constant.. until i cleared it ...
    hasn't come back since...
    -18F here... windchill -35F or so
    *fingers crossed*
    Lurker
    Established Member Two Rings crosenhahn's Avatar
    Mar 13 2008
    2001 Audi S4
    Colorado Springs
    Mine has just started doing that this winter...I have no idea what it is.... Someone please help!
    01 S4 - Stage 2+
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    Mine came on the second day of ownership, and has stayed on. It's so frustrating.
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Veteran Member Three Rings willowtreexx's Avatar
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    I know im from the A4 side but mine has done the same. I was told that there are connectors under each front seat and they can come loose causing the light to come on. Make sure they are seated VERY tight. Should solve the problem. If not it might be the airbag brain module which is a fortune
    2000 A4 1.8TQ Auto tip
    Unitronics Stage 1 chip / H&R coilovers / 18x8.5 MRR GT1's/35% tint
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    run vag-com and make sure you didnt get the dreaded airbag control module code.
    Its ok if you do get it, you can get your module rebuilt for around $50.
    B5 S4 AWE Stage 3 - sold
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    My dad had an is300 that did that. he took it to the dealer and they had no idea why it was doing it.
    the homebrew'd s4
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    i lost my airbag controller on the coldest start I ever did in the winter of 2008, had to replace it
    My car is fast
    Senior Member Three Rings AK1RA07's Avatar
    Dec 07 2007
    2001 S4, 1992 Miata, 1993 RX-7
    DFW
    Mine does that too.. it comes on in the cold, but once the car warms up, it flickers and goes away.. dunno why.
    Sep 20 2007
    Harrisburg, PA
    Quote Originally Posted by AK1RA07 View Post
    That's exactly what I'm talking about. Wish I knew.....anyone? :)
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    I had the same issue a few weeks ago, it came out to be the airbag controller. It as an easy replacement, only special tools needed were radio keys. I followed this DIY http://www.audiworld.com/tech/elec152.shtml.
    My symptoms were: airbag light on a cold morning starts, and it goes away once warmed up. Doesn't come back on until the car has been left sitting overnight.
    TEAM|AXION
    Veteran Member Three Rings audikidS4's Avatar
    Sep 03 2008
    2001.5 S4 Avant 6spd - Sil/Blk, 1995 S6 Avant - Blk/Ercu
    Wareham, MA 02571
    Yes! Mine did the same thing. At first it will go out when the car warms up. Then in a little while it will be on all the time. You need a new airbag controller (the one under the stereo) module! :(
    The original audikid! Coined as ebay username spring 1999.
    **MTM ECU, Piggies, ASP Tru-Duel, Stratmo ss kit, Stern sm, AWE DTS, Voltgland GT2, Neuspeed 19mm RSB, full Samco kit, drilled and slotted rotors, PODI/S-W boost gauge, Sportec pedals, 30% Huper optik, CCMod, stubby antenna, VMR 708s 18X8.5 32mm**
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    Quote Originally Posted by Rajan147 View Post
    where can you get it rebuilt for $50 any links?
    Jul 01 2008
    Minnesota
    Yeah it sounds like a module or communication issue to the instrument cluster. The lights should stay on once they come on until they are cleared, they shouldnt go away on their own so thats why Id bet one the control module being the issue.
    Jul 01 2008
    Minnesota
    Quote Originally Posted by willowtreexx View Post
    Those rebuild places often dont work very well. They typically just reflash the software and the code will come right back because the software issue was caused by a hardware issue which they dont address. Unless theres a place im missing that does a better job...
    Sorry for the double post.
    Nov 23 2007
    Columbus, OH
    Senior Member Two Rings S_four's Avatar
    Dec 13 2005
    2013 Sierra, 08 Grizzly
    It says "100% Guaranteed Service or your money back." Sounds good to me. I need my light to go away as well.
    01.5 S4
    3L GT || R8 Reps || Vogtland Coilovers || Some other stuff too
    Jul 01 2008
    Minnesota
    Yeah, most back it up. The problem is its been a hassle for most people ive talked to. They send it in, it either comes back with a light or the light comes on again soon after, then the place tells them to send it in to try it one more time (why not do it right the first time, if it happened once itll happen the second time is the way i see it), they send it back, then recieve it, same thing happens and then they get there money back. Its a hassle if your gonna be putting everything back to normal each time, other option is to leave everything torn apart. Its not a bad price if it actually works for you though.
    Established Member Two Rings jay340S4's Avatar
    Oct 03 2008
    2000 Audi S4, 2009 Dodge Ram 5500, 2002 Toyota Highlander
    Prince George, BC, Canada
    Mine does the exact same thing, when it cold it comes on, but when it warms up it goes out and there dosen't seem to be anything wrong, just dosen't like the cold I guess.
    Apr 18 2007
    LO, OR
    My light was on all the time, VAG says it's the airbag control module. I've sent it to airbag systems twice now with no luck. Anyone have any luck with airbag systems or another company rebuilding it? If you had luck with airbag systems, what did you do, am i missing something? I'm willing to try one more time with another company before buying a new one. Thanks
