Results 1 to 4 of 4
    Veteran Member Three Rings HamidsVikes's Avatar
    Jan 10 2008
    Vancouver, BC
    Help... my bumper fell off and I cant put it back on! with pic!
    http://i149.photobucket.com/albums/s...irthday018.jpg
    Long story short....
    I used my car as a snow plow, which caused my bumper to break off...
    as you can see in the photos the latches have snapped off. I do have most of the peices, my question is, can this be fixed or do I have to buy a new bumper?
    thanks
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Help... my bumper fell off and I cant put it back on! with pic!
    Well since the bolt holding tabs tore the plastic off your front bumper you will need to get those fixed. You might be able to build a wall cavity and fill it with plastic epoxy then sand down when dry. Or take it to someone that has a plastic welder. Unscrew the nuts and the bolt tabs should come right out of the fender. Might need to brace the tab side if they are loose in there so it doesn't spin on you.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by CO AVANT View Post
    ... uhhh what he said lol
    - Clint
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    that may be tough. take it to a bodyshop.
