Results 1 to 30 of 30
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Anyone do the Aero wiper upgrade?
    Looking at this kit from ECS
    Aero Wiper Kit
    Anyone else do this? The standard wipers do a poor job and leave those three contact lines across my windshield. Even on fairly new blades.
    Thoughts?
    Oct 27 2008
    Boulder
    Re: Anyone do the Aero wiper upgrade?
    My standard one was the same. Thus, I upgraded to aero one.
    Now, it works great.
    You can buy it on e-bay.
    Buncha motorcycles
    Memphis, TN
    yes, they look better and do a better job in summer but suck in winter time. i guess when the rubber gets hard it doesnt conform as well.... wiper arms are a BITCH to get off, just keep beating them with a hammer
    APR Stage 2/AWE Intake
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    i got those from ECS. my wipers slipped on the motor and were not in the right position so they ended up trying to dive down into the engine bay. i had to take it all apart to get in there and tighten the bolt on top of the wiper motor while trying to keep the wipers in the correct position, it was such a bitch i ended up throwing one of the wipers at the garage door and busted it all up, and that is why i now run aero wipers....... :P
    I don't have any problems with them except when it's below freezing and they get iced up, but your going to have that with just about anything.
    Oct 27 2008
    Boulder
    when you install that, don't beat that too much.
    first, just spray the WD-40 as much as you can, and wait (in my case wait 1~2hours).
    and then pull it out.
    You can find the thread on the diy forum.
    Senior Member Two Rings A4monkey's Avatar
    Aug 02 2007
    2004 Audi A4 3.0L Quattro 6sp.
    Nutley, NJ
    $130 for a set of wipers is a bit excessive. I think just getting a set of Bosch Icons is probably a better option. Plus the Icons will run you around $40 for the set. I had the Bosch Icons on my previous car and loved them, both my brother and girlfriend have the Icons on their cars now as well and are very satisfied.
    Mar 20 2006
    Thanks guys. Just ordered up the kit.
    Widgget, you get my PM?
    Dec 18 2007
    nj
    just replied. :)
    Veteran Member Three Rings Tomek6's Avatar
    Dec 29 2006
    2005 A4 USP 6spd
    I live in Canada so it's cold half the year. I never had a real problem with the factory wipers. But I'm curious if there is anything better. Mainly for winter.
    2005 Audi A4 USP 6spd |Revo Chip|TT 225 Injectors|Evo MS Intake w/ modified stock ram air|Samco Hoses|Forge TIP|Forge DV|VMR TP|Custom SS 2.5" Magnaflow Exhaust|ECS Snub Mount|KW V2 Coilovers|Hotchkis S4 Sways|BBS CH's|3.0 C/D, Slotted Rotors|USP Front, Rear Spoiler and Interior Trim|Cupra R Lip|B7 Rear Valance|DTH Sideskirts|Grilles|E-Codes|S4 Mirrors and Door Blades|S/w Boost Guage w/ Podi Steering Column Pod|
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    97 A4 2.0TQM
    Rochester, NY
    http://www.wescotools.com/p-10683-li...rm-puller.aspx
    buy one of those
    you'll thank me later if you do
    the one in this picture is junk, don't waste your time with it. breaks too easily and doesn't fit right.
    Dec 18 2007
    nj
    turn the wipers up so they aren't against the windshield (this will release the spring tension and allow the wiper to slip straight up from the bolt, other wise the spring puts tension on it at a weird angle and you won't be able to pull it off) use a little force, maybe a small flat tip screwdriver and you'll be all set.
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    aero wipers are terrible in poor winter conditions. it has even become dangerous in a blizzard out here in the mountains.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Apr 20 2007
    Lander, Wyoming
    Quote Originally Posted by pac1085 View Post
    buy one of those
    Im 99% sure you cannot fit that Lisle tool onto the driver's side wiper without releasing the hood strut and/or removing the hood. The "junk" tool barely fit and if you leave the nut loosely on the wiper post it works flawlessly, I used it last night with no trouble whatsoever. No it's not the nicest tool or brand in the world but it works, is readily available at any chain auto store and has a Lifetime Warranty. What's not to love?
    Jon
    go > show
    Ich liebe mein Audi
    Veteran Member Three Rings Pete4 1.8t's Avatar
    Jan 13 2007
    '12 328i Sport, Others: '12 A8L W12, '12 S5 Cab, '11 P. Cayenne, '13 P. 911 C2S
    Greensboro
    I've done it and can say it was worth every penny. The standard wipers sucked! Also installing them was a PITA but worth the effort.
    2003 Audi A4 1.8t 5-Speed
    Light Silver with Ebony Leather with Premium Package
    Veteran Member Three Rings darkstar's Avatar
    Dec 25 2004
    1998 silverado, 1986 c10
    Folsom, CA
    I have taken my wipers off a few times I never had a problem ever getting them off.. Never had to use any force at all. I believe widgget is correct on pull the arm up to release the tension.
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Tirerack is selling valeo Aer for $19.99, buy one get one free. Mine are still wiping perfectly after a year and half a multiple trips to Lake Tahoe.
    TEAM|AXION
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by darkstar View Post
    are you talking about just the blade? we are talking about the arm itself coming off the motor. it uses some kind of tapered rod with splines that help lock it on. sometimes (usually) they are very difficult to get off. you have to bend the arm up otherwise you will crack your windshield trying to pull it off
    Aug 10 2008
    UK
    Has anyone done a rear aero wiper upgrade on the avant? Hmmm, maybe I should post it in the Avant section later...
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by KPC1.8TQuat View Post
    Aero Wiper Kit
    Thoughts?
    I have them in stock, ready to ship at a pretty good price http://www.shop.dthaus.com/product.s...&productId=127
    Jun 23 2008
    http://www.autohausaz.com/search/pro...ade%20Assembly
    Would that first Bosch Aero wiper set for $33 attach onto my regular OEM wiper kit or do I need another component for the Aero's to work?
    Jun 23 2008
    Quote Originally Posted by DownhillA4 View Post
    Bump, any answer to this question? Thanks!
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    Yes you need the arms that come with the kit. At least i had to switch from the oem to the aero. Maybe the rain x ones might?
    Dougs write -up.
    http://www.audizine.com/forum/showth...el-Aero-wipers
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Jun 23 2008
    Quote Originally Posted by A4Maine-iac View Post
    Dougs write -up.
    Thank you!
    Active Member Two Rings iceman2k's Avatar
    Jan 09 2011
    Vancouver / BC
    I just upgraded mine today and I think this car is cursed! The driver side wiper doesn't touch for about 5 inches in the middle of the blade, so I now have a nice big section that doesn't get wiped right in front of my eyes...
    Other then that, the new Aero wipers are great.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by iceman2k View Post
    Try swapping the left blade with the right blade.
    Active Member Two Rings Fabes02's Avatar
    Feb 19 2012
    B6 A4 1.8t APR stage 3+ / '11 Nissan GTR (R35) Switzer P600 Matte Black Wrap 3M (646awhp)
    Las Vegas, NV
    ALRIGHTTT!! finally a solution for new aero wiper blades! Im soo tired of go to the dealership for those s***** standard wiper blades, god they suckk. LOL
    I was wondering when a company was going to make replacement blades or even arms for our B6, euro style. FINALLY! =))
    +1 for me! ::buy now::
    2004 Audi A4 1.8T(Blue) APR Stage 3+ ---sadly selling, will miss this car =( ----
    2011 Nissan GTR R35 (Matte Black Wrap 3M) Switzer P600 646awhp w/ Volk TE37's Black 19 x 10.5
    Coming soon to my garage, new daily driver. 2012 Audi S4 (White) w/ VMR V710's Matte Black 19 x 8.5
    Veteran Member Four Rings MNAudi101's Avatar
    Aug 18 2011
    Stuff
    Minnesota
    I always thought they werent worth it but after having mine for a couple weeks now they are awesome, they look better and work better but if you dont want to spend the money from ECS which is still a good deal try car-part.com and look for 05 A4 or a B7 A4 and call around, that is what I did and got mine arms and blades for 50 bucks. most junk yards just see them as another wiper arm so there prices arent high. 24.99 a side, cant beat that
    200k daily tank
    My Build Thread
    "Like a fat chick in Yoga Pants...Mad stretch "
    Feb 19 2012
    Las Vegas, NV
    the B7 A4 arms and blades will fit the B6's???? Well it should because your replacing the whole arms etc..etc. right??
    Aug 18 2011
    Stuff
    Minnesota
    yup they do
    200k daily tank
    My Build Thread
