Results 1 to 14 of 14
    Registered Member Two Rings
    Mar 21 2007
    Silver 02 Audi A4 Avant 1.8TQM
    Germantown, MD USA
    ECU flashes in MD?
    I have an SAI code(P0411). I've been reading about it and will try and fix it but if I can't I'd like to just turn the emissions codes off. What are my options to do this? I'm assuming MD shops can do it. How much would they charge, do you think? How about owners with tuning software? What software could remove these codes and do a lot of enthusiasts have it? If so is there anyone close to me that I could maybe swing on by for a quick flash?
    I live in Germantown, MD(Montgomery County). So any info on shops or individuals near me that could help would be really appreciated.
    Thanks,
    Mike
    2002 Audi A4 Avant Quattro 1.8T 5spd Silver
    2000 Pontiac Formula Firehawk 5.7L Supercharged 6spd Navy Blue Metallic
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: ECU flashes in MD?
    Not really, you might get Uni or Tapp or someone to write it out, but the main tuners will not
    - Clint
    Senior Member Three Rings gullatec's Avatar
    Sep 10 2008
    baltimore, maryland
    I would call induktion.
    brandon
    USP CLUB MEMBER #119 | dolphin gray | 6SP | UNKNOWN TUNE | TT225 (sitting in a box) | podi | cupra-lip | 6000k Fogs | 20% tint | slow
    Currently: Stage 1ish
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Quote Originally Posted by gullatec View Post
    What he said.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by buschman View Post
    Thanks,
    Mike
    Go to RAI and get a UNI flash. They will take care of that code for you.
    Oct 29 2005
    10speed
    San Francisco, CA
    They wont be able to do anything
    - Clint
    Mar 21 2007
    Germantown, MD USA
    Quote Originally Posted by Don Supreme View Post
    What is RAI? Is this a shop? I don't know what RAI stands for or where it's located. Thanks for the heads up.
    Mike
    Oct 29 2005
    10speed
    San Francisco, CA
    Mike
    Yep, great shop, guy who owns it's name is Ray, he posts on here as Rayveedub. Anyway the shops # is 443-600-4982
    - Clint
    Mar 21 2007
    Germantown, MD USA
    I spoke with ray and the UNI flash is out of my price range to fix this problem, but he did suggest the resistor or diode mod. Does anyone have any info on this? What type of resistor and where does it go?
    By the way I really like honest shops and ray struck me as a very honest and helpful guy. Especially if he knows of a cheaper way to do something and tells you about it while it potentially costs him business. If I need work done on my Audi I will definitely be giving him a call.
    Thanks for the suggestion on Ray. now does anyone have any links or ideas on this resistor mod?
    Mike
    Senior Member Two Rings p.tony's Avatar
    Sep 02 2007
    2000 s4 Stage 3, 1997 Lexus sc300 na-t, 2004 Touareg v8, 2007 Corvette
    Baltimore, MD
    Why not let Ray do the resistor/diode mod? Throw him a bone man
    00 C5 2.7t //Stage 3//
    Oct 29 2005
    10speed
    San Francisco, CA
    Mike
    ray is the man, you need a resistor and you wire it into the plug to make the ECU happy
    - Clint
    Mar 21 2007
    Germantown, MD USA
    I ended up fixing the problem itself. Once I got in there it was so obvious that the little tube was sheerd off. It ended up not costing me a penny. Thanks for the help though guys.
    Mike
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    What was the code for what did 411 stand for.
    Mar 21 2007
    Germantown, MD USA
    P0411 is referring to the Secondary Air Intake, or as us domestic guys call it, EGR(exhuast gas recirculation), or the common name, the combi valve. The combi is on the back of the intake. So the 411 code means there is somethin g not right going on with the combi valve. I think the most common error, and thankfully easiest/cheapest to fix is the vacuum line going to the combi vlave breaking down, falling off, or leaking. It gives an inaccurate readings and throws the code. I've heard others say the car idles funny at times, and a loss of gas mileage. Although I didn't notice any of those as the car drove perfectly.
    Other parts of the SAI/EGR system can go bad. The combi valve can clog or the SAI pump can fail as well. Obviously those are sliughtly more expensive to fix, but fixable.
    Good luck.
    Mike
