Results 1 to 2 of 2
    Senior Member Two Rings EnjoyIncs's Avatar
    Oct 24 2006
    '04 S4 DG
    Worc MA
    Passenger side Bose speaker grill
    My friend put his boot threw the front speaker grill. My question is can just the grill be replaced or does the whole door panel need to be replaced? Is the only place to get it the dealer? And can it be install by me?
    Thanks
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    Re: Passenger side Bose speaker grill
    i replaced one on my B5 it was simple just take the door panel off and use a chisel/sharp knife to cut the melted plastic tabs. old grill should pop out, slide in the new grill and use a bit of glue on the plastic posts.
    when you get into the door it should be come clear.
    also the replacement did not have the Bose logo on it, so i took it off the old and glued it on the grill.
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
