Results 1 to 19 of 19
    Jul 19 2007
    97 A4 1.8; widebody MR2 turbo
    San Jose, CA
    So my head gasket is done for...
    What a bad day...I arrive at my friends house to play guitar hero and sure enough my oil light comes on so i go to add oil and just my luck my oil cap is milky white...Fortunately now i get to replace my head gasket with a 034motorsport gasket that will lower my compression!
    I have a few questions because i plan on repairing it on my own:
    1) Will i need any special tools to pull the head?
    2) Does anyone know any good sites to visit to maybe help me through the repair?
    Any input would be great. Thanks guys
    PC-16 K04!
    Veteran Member Three Rings LEGO's Avatar
    Aug 20 2007
    SEATTLE, WASHINGTON
    Re: So my head gasket is done for...
    1998 A4 1.8TQM MTM K04 5.82/034 415CC BT TUNE/GENESIS 415CC INJECTORS
    http://s22.photobucket.com/albums/b331/nelly11299/
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    that is pretty much everything you would need to know. You CAN get away with not removing the front clip if you are very careful, but it would be easier to remove it for your first time and safer (timing wise). You'll need the head bolt tool, can find them on ebay or possibly a local store like eppys had one for me. You will need new headbolts since there are one time use. And I would try and replace everything you can that is a wear and tear item that may leak like the plastic pcv breather tube off the block, make it easy while everything is apart rather than fighting with it when your car is together.
    BTW why would you want to lower your compression? IDK anything about 034's, they make good prodcusts, but I have heard bad stories with some other cars (not audis in specific) about headgaskets that space out the block and head for lower compression
    Jul 19 2007
    San Jose, CA
    Quote Originally Posted by njm23 View Post
    thanks man, Yeah i found a few places that sells that tool so i should have no problem picking it up. As for the compression lowering, I thought it might be a good idea to drop the compression because I run about 19 psi on my k04, but im starting to have second thoughts on whether or not to just get a regular head gasket. What do you think would be a better option?
    PC-16 K04!
    Jul 03 2008
    A4
    i have 9.25 : 1 cr on a gt30 runing 20plus psi on 93 oct no problems, leave the cr.
    low cr = low hp
    Jul 19 2007
    San Jose, CA
    Hey Njm23, How long did it take you to do your head gasket replace? and how hard would you rate the job. I know I can do it, i just want to know what to expect going into it
    PC-16 K04!
    Jan 25 2006
    A4 2.0T
    MD
    ---- Use a stock replacement headgasket...
    You don't need to drop compression.... (Planning a BT upgrade maybe? -- you would need rods too).
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    did you do a compression/leakdown test to make sure it's the head gasket and not the oil cooler?
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    lower compression = able to run more PSI of boost, but less HP off boost. since you have almost maxed out your k03 already, you cant run more boost, so lowering your CR would only loose you power without upgrading your turbo.
    Veteran Member Three Rings oldblu's Avatar
    Jan 01 2008
    Budd Lake, NJ
    is the 2.8 the same?
    --Silver 2000 A4 2.8L V6 Quattro
    S4 Bumper. Borbet Type LS Wheels. M3 Replica Spoiler
    Blue! How come there's no ice
    in my lemonade?
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by oldblu View Post
    In what respect? The 2.8 is VERY different....
    because racecar.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Kyle H View Post
    yea in what way? lol they are both B5s thats about it
    - Clint
    Jan 01 2008
    Budd Lake, NJ
    that was very general. It feels like it's much easier to do the head gaskets on a 1.8 - what would I be getting myself into if I did them myself on my 2.8? How many things would I be taking apart? (Don't mean to thread jack) They're getting done in spring so it's between professionally, or myself
    in my lemonade?
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    I think the only difference on the 2.8 would be that you have to take off two heads instead of one.
    because racecar.
    Jan 01 2008
    Budd Lake, NJ
    I thought it was more involved than that. I think 2.8s are a kinda crowded which would mean I'd have to take things off before I get to the gaskets
    in my lemonade?
    Nov 03 2008
    98A41.8TQM
    in both engines you have to take everything apart. you may have to move a few more wires or something for a 2.8 but the main difference would be the fact that you have twice the heads to take apart. 2 gaskets, twice the bolts, etc. other then that its not much more involved then a 1.8t
    Feb 28 2007
    04 a4 USP ; ATS
    WELL, since you asked. I had to pull my head off today actually. I started at 1pm, head was off around 3pm and I took my time. Granted i did not take off the front end of the car I just fiddled with the t-belt tensioner and slid to belt off the cam gear and makred where it was. F-ed up HG FTL, brand new head too. machine shop just called saying it was 100% flat, so install error?idk
    Regardless, if you have done any work on this car it is a piece of cake, just analyze things before doing them and you'll have no problem haha. Should take someone who hasn't done it like 6-7 hrs to go straight through. You getting your head resurfaced or anything? How and why did the HG go? You just need your basic metric sockets and allen/hex sockets and the headbolt tool. May consider changing out the t-belt while in there if it has not been done in a while. make sure you remove and tighten the bolts in the correct order!
    shoot me a PM if ya got any questions that go unanswered.
    Quote Originally Posted by grannyA4 View Post
    Jul 19 2007
    San Jose, CA
    Thanks man, that helps a lot! yeah I think I'm going to change my t-belt as well as my water pump and thermostat since I'm in there. Another question for you regarding the T-belt; when replacing it, do i have to make sure that the belt is in the correct position or anything as to not screw up the timing?
    PC-16 K04!
    Feb 28 2007
    04 a4 USP ; ATS
    well it isn't possible to put "the belt in the wrong position". Basically Just make sure your crank and cam gears are both timed correctly, then slip on the belt which ever way you find the easiest. The side that goes from the cam gear to the water pump then crank bolt should be taught even before you release the tension in the tensioner fyi. Look at a t-belt diy for a more detailed post with pics if confused on that.
