Results 1 to 9 of 9
Thread: Engine Knocking
    Sep 22 2008
    Nor Cal, Petaluma
    Engine Knocking
    I have searched this topic so I don't want to get flamed on but I am worried about the avant. I recently had an oil change done and I just got a service oil light about 3 days ago. There is a knocking sound when the car is idling but you can't hear it when you are driving. There is a whining sound coming from the engine when I get up to about 2500 rpm and above but I believe that is just my turbo giving up. I am more worried about the engine knocking. I searched this and saw that it could be the timing belt tensioner. Btw the knocking is faint but def. audible. Any help is much appreciated.
    Established Member Two Rings pA4AWDd's Avatar
    Jan 14 2009
    Jersey
    Re: Engine Knocking
    Sound like what happened to me when I had a bad coil/ and was misfiring. I replaced the coil pack and walahh, no more of that business.
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    Re: Engine Knocking
    Also sounds like your oik pump I believe it is. A lot of ppl have this problem when idling including me. S
    Sep 22 2008
    Nor Cal, Petaluma
    Re: Engine Knocking
    Is the check oil light on? Also any harm done to the engine if I continue to drive with a bad oil pump until I get a new one.
    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    Re: Engine Knocking
    Quote Originally Posted by pA4AWDd View Post
    doesn't the CEL come on if you have a misfire which also tells you what cylinder?
    Sep 22 2008
    Nor Cal, Petaluma
    Re: Engine Knocking
    I don't have a CEL just the service oil light which turns off after a few minutes or so.
    Jan 14 2009
    Jersey
    Re: Engine Knocking
    My CEL has been flashing for months ha...and it never specified which cylinder is misfiring. I went through 2 coil packs in a matter of 4 months. The second time it happened is when I got the knocking and extremely low rpms during idling, and no power after 10 mph
    Sep 22 2008
    Nor Cal, Petaluma
    Re: Engine Knocking
    so will vagcom tell me why the service oil light is on?
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    Re: Engine Knocking
    If the lcd screen says service oil your milage counter for the mainence light wasn't reset, if you have a pic looking like an oil can you have too low of oil pressure. For the knocking did you check the oil level? Is there smoke coming from the exhaust?
