Results 1 to 25 of 25
    Nov 02 2007
    03 B6 1.8T TIP
    Richmond
    How much gain for test pipe?
    Eurocode says that it has a solid gain of 15hp, is it really? I have a custom downpipe, custom exhaust manifold, borla catback after adding the testpipe will it be loud?
    "When you love somone, you let her sleep well"
    My...2005
    Coiming this Summer: VIS Carbon Trunk w/carbon lip spoiler. CF splitter...
    "The fastest B6 TIP in Richmond BC"
    May 26 2005
    CLS63tt
    Boston
    Re: How much gain for test pipe?
    if u have software its worth it.
    speaking of which, anyone wana buy a 3" eurocode tp? :)
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    I'll will be louder, you are cutting out the resonator I presume as well. You will gain higher boost round mid revs so like 3-5 x1000. Also with all of that there should be a solid gain of 15-25 hp.
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Senior Member Three Rings vc1492a's Avatar
    May 04 2008
    Knoxville, TN
    Quote Originally Posted by pizdetsauduxa View Post
    interested!
    2010 A4 2.0T S-Line Cab (CVT)
    2004 Stage 2 Mini Cooper S
    Sold: OEM+ 2005 Audi A4 USP 1.8T
    Buncha motorcycles
    Memphis, TN
    there is some arguement on if a test pipe actually helps or hurts. it really depends on your setup (stage 1/1+ or BT/BAT) the BT/BATs certainly get some solid gains from it. i couldnt feel any gain in power after going to a full neuspeed/test pipe. perhaps quicker spool, it wasnt like the difference i immediately noticed with the FMIC. Someone even did a dyno before/after and showed 0 hp increase.
    i will point out it lowers your EGTs and allows the car to return to normal operating temp much quicker which keeps oil from cooking on your turbo. im very happy with mine though, it might help more at speed where its harder to feel the increase in power
    APR Stage 2/AWE Intake
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    Agreed 100%^^^^^
    I did my TP before installing my full exhaust and the main difference I noticed were quicker spool (a few 100 RPMs sooner) and my turbo wouldn't be glowing like a cherry where previously after even slightly spirited driving it would be nice and red (lower EGT's).
    It "felt" like it gave power under the curve, maybe not any gain in peak, but my car felt stronger in the lower mid range and didn't choke out quite as bad up top.
    Jan 17 2008
    05 A4 QMT6 USP Moro Blue
    So if you have stage 1+ which is 235hp, with a test pipe you should have around 250? Ehh...Is that right?
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by jessefrank View Post
    Agreed 100%^^^^^
    thats what i was trying to say! definitely more power under the curve when you are rolling..
    yeah, with stock programming,exhaust and cat my turbo,mani and cat would glow cherry red now i have 1+ running 2.5x the boost with the neuspeed and a test pipe and i can barely get it all red...
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by ppcastel View Post
    probably not.. maybe 5-10 more
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    doesnt the tp do more for tq?? and not peak tq, but off peak tq?? thats where the quicker spool comes into play right??
    May 04 2008
    Knoxville, TN
    so a test pipe's a good idea even if you're on stock programming? Im seriously thinking about it
    Feb 06 2008
    03 a4 tip
    CAL, PA
    I love mine. Gives the car a more aggressive note too. Just do the whole exhaust system at once.
    z
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by vc1492a View Post
    even on stock software, its still going to lower your EGTs and let your turbo cool down much quicker which is better for your oil. I just crack my door now and let it idle till the ding stops (about 1 minute) i vagged it and as long as i drive easy the last few miles its down to 400-425 egts within that one minute
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Papa, do you get a CEL with your TP? I know you and I have been talking in TP posts all week, and the more I think of it, I am now leaning towards getting one.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    You'll get a CEL without some kind of software file or antifoulers.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    I dont think a TP gives any HP. IMO it gives a quicker spool, 300-400rpm sooner, It gives a good kick in pants feeling... It's an important part in the plenty of part that help our car but has not the 15hp claimed by ER. HP are much more difficult to gain but I would say that it probably a good 10 hp on the butt dyno!!! It's significant in the lower rpm's...
    that's my 2 cent
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Feb 07 2008
    just the a4
    northeast pa
    the tp wont give you a higher peak hp or tq, but say at 2800rpm (and i have never seen a dyno so p-p-pplease dont flame my example) but say at 2800rpm you had 200hp and 250tq.. your max hp and tq are 265hp and 330 tq. w/ a test pipe, your max numbers wont change but u'r hp and tq at 2800 will go up since you are seeing higher boost at that rpm.. am i right???
    May 01 2008
    Winter
    I think those numbers are absolutly nothings but you could say something like that... Your peak HP and tq will not change but the curve in the lower rps will increase...
    Feb 07 2008
    just the a4
    northeast pa
    that's a better and easier way to say it... u just see the power sooner..
    Veteran Member Four Rings traf818's Avatar
    North Hollywood
    There are dynos out there that show test pipe gains. And for the money it's well worth it.
    -Ralph
    F10 550i M-Sport
    Mar 20 2006
    Quote Originally Posted by traf818 View Post
    Someone find examples. My guess is that a TP will marginally increase peak HP and torque, but will have a significant positive effect on the area under the curve.
    This is of course aside from the proven fact that a TP will decrease your EGT's which is beneficial to the entire health of the motor.
    Someone post dyno examples.
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    You guys all have valid points. I ran Revo Stage 1 with cat back maganflow exhaust for about 2 years before I installed a testpipe. Once I did, I felt it totally changed the characteristic of the car as far as power under the curve. The stock CAT chokes the engine so bad, and my measly 2.5" testpipe made the car flow better.
    I always hear people talk about how they prefer a HFC because of legal issues. However, the way I see it, the cop can still write you a ticket because most HFC are not CARB legal anyhow. Plus the cost of the HFC will be equivalent to the TP+ticket+unistall+install back again LOL. I mean I got my my jeff pipe for about $100 and paid $100 for the install. Not bad IMHO...I am sooo glad i paid for that !! I would have been so pissed off because the shop had to make modifications to fit my downpipe...
    another stereotypical Audi
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    You can never really go by those tuner claims. Plus with whp so different than chp you just have to take it for what it is based on your mods. I felt gains on the butt dyno with Revo 1+ but for the minimal cost it's worth it just for the sound(even with stock exhaust) assuming you don't have strict emission regs to deal with. And for the record, in NV I rolled up to get smogged like nothing was wrong with my TP installed, and they did a simple ODB2 scan and I passed with flying colors. Of course you must remember that I have the REVO file for no CEL and if you have a cel for whatever reason you automatically fail (though u do get a discount on the retest).
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    ECS threw in the test pipe programming along with my APR 1+ tune so that i wouldnt get a CEL once i put a full turbo back on.
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    Jan 17 2008
    ^^^ eurogruppe, how much louder was your car when you added the tp to that decorsa exhaust?
