Results 1 to 26 of 26
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    just installed 6k bulbs from DDM tuning.. but.... help!
    It took me 3 weeks to receve my bulbs from DDM Tuning.. But finally i got them. They look great! ( Pictures to come soon )))
    But i cant adjust my headlight level.. I turn the god damn thing clockwise for ever to try and lower it and the beam level wont move... help!!!!
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Re: just installed 6k bulbs from DDM tuning.. but.... help!
    Look for a white screw...
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Sep 27 2006
    Quote Originally Posted by Turn10 View Post
    huh.. its the outer white screw.. and i turn it clockwise and it doesn't do anything for me..
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Jan 11 2007
    Salt Lake City, Utah
    how blue are they compared to stock?
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Established Member Two Rings RitchS4 914's Avatar
    Sep 29 2008
    Yonkers NY
    what bulbs are they exactly? I'm looking to get the same ones. A link would be great, thanks
    00 silver b5 s4
    -stage 2+.. Soon to be stage 3...
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Quote Originally Posted by Bigair View Post
    Should be 2 plastic adjuster screws
    One's for lateral adjustment, the other's for level.
    If neither are making any difference to the beam, then I'd suspect the adjuster threads are stripped.
    Or the adjusters have seperated from the reflector assemblies...
    Jan 09 2008
    United Kingdom
    For the greatest light output, I'd suggest 4300k.
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    What is the complete kit you purchased?
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    You can't adjust them just by turning the screws, you have to go in VAG-COM and set it (I forgot the parameters) and THEN you turn the screws.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    Quote Originally Posted by Rated S View Post
    really?
    Sep 19 2008
    Toronto, Canada
    More details?
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by CONTROL ONE View Post
    More details?
    Yep. Stock motors dont turn unless you tell them to "LEARN" a new position...
    http://www.ross-tech.com/vag-com/car...alignment.html
    Thats the procedures..
    For the lazy.
    Ross-Tech is not responsible for any damage or problems that may result from following these instructions. They are to be used at your own risk. As always, you should refer to a Factory Repair Manual for your vehicle!
    This procedure applies only to older Xenon systems that use KW-1281. Procedures for specific vehicles, including newer cars that use KWP-2000 or CAN systems can be found in the Ross-Tech wiki.
    This procedure details how to perform a Xenon Headlamp Adjustment on many VW/Audi vehicles equipped with Xenons (HID's). This procedure cycles the motorized headlamp adjusters to their center position so that the beams can be adjusted. This does NOT align the headlamps by itself. You still need to manually adjust the headlamps via the adjusting screws as referenced against a suitable aiming target.
    If this procedure is only partially performed, there may be a DTC stored in the Xenon Range memory indicating "Headlights not adjusted". To clear this, you need to complete the entire procedure.
    There are certain test conditions that must be met before doing this procedure:
    • Vehicle must be parked on level ground and "settled" on its suspension
    • Parking brake should be OFF
    • Ignition should be in the "On" position
    • Headlamps should be "Off"
    Procedure for Aligning Xenon Headlamps:
    [Select]
    [55 - Xenon Range] (For some newer vehicles, use [29 - Left Light] instead )
    [Basic Settings - 04]
    Group 001
    [Go!]
    Wait at least 20 seconds for the headlamp motors to move. The headlamps are now in their adjustment position. Turn on headlights. Adjust them via their manual adjusting screws as referenced against a suitable aiming target.
    Scroll up to Group 002. The Xenon Range controller has now learned this position as its Home position.
    Click the [Done, Go Back] button and you're all set.
    Note: There have been reports of lowered vehicles displaying an error message in either Basic Settings group 001 or 002. If the vehicle height sensor(s) are bottomed out, it may be necessary to bend the sensor bracket to allow normal adjustment to occur. Also, check to make sure that the sensor arms do not have their pivots facing the wrong direction as shown in this thread: http://forums.vwvortex.com/zerothread?id=2383036
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Thanks, I was already late for work.
    Sep 19 2008
    Toronto, Canada
    ASB5S4, thanks!
    Sep 27 2006
    oh damn.. thanx i have to try this
    and 6k HID bulbs from DD Tuning are great.. they have that blue ish / little bit of white feel to them.. not too blue.. When you first turn on your HID lights color...
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Sep 27 2006
    http://www.ddmtuning.com/hidkihidbuhi.html
    HID Bulbs Sold in pairs only. Bulbs sold come with the industry standard Amphenol type connectors. Sinc we have no way of knowing which ballasts bulbs may be attached to, we can only offer a 1 year warranty on separate bulb sales. Even so, these are the same bulbs contained in our Lifetime Warranteed DDM bulbs. Sold only in pairs for proper color and brightness matching.
    pad
    HIDBULBSpad$30.00pad
    I got D2S 6000k
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Jan 11 2007
    So I just got a new set of headlight housings and can't slide the stock leveler motor up in the slot because it's not long enough. Do I just adjust the white screws on top of the light to get it to slide in, then adjust it via VAG-COM, or do I plug the motor into the electrical connector and make the motor push the thing out via vag so that I can slide it in?
    LOOKING FOR:
    Nov 22 2008
    01.5 S4
    Michigan
    how did you install them did you have to use the condersors??
    Sep 27 2006
    No Luck Using VAG-COM ... what could be wrong??!
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Veteran Member Three Rings GetAudiHere's Avatar
    Mar 06 2006
    Minnesota
    Hmm weird. i thought you just adjusted the white plastic screws as well...
    Make sure you post pics of this setup when you get a chance!
    Jun 14 2007
    2000 S4
    Connecticut
    did you have the ebrake off and all that?
    Sep 27 2006
    yeah and it the vag com come said it was in adjusting mode and everything... so i went to adjust them.. no movement... this is really pissing me off.. they are set so high up my brights don't do anything..
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Sep 27 2006
    still no luck. someone help
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Senior Member Two Rings jayski006's Avatar
    Dec 06 2008
    Toronto, Canada
    ever figure out how to do it.. i'm in the same predicament?
    Sep 27 2006
    headlight is crack on the inside..
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Apr 13 2008
    Tennessee
    make sure the threads aren't stripped out
    also, make sure you put the bulb and ignitor back into the headlight so the back cover isn't messing with the ignitor and forcing it up - btdt
    you shouldn't have any problem using the vagcom to extend the motors
