Results 1 to 24 of 24
    Veteran Member Four Rings anmagro's Avatar
    Sep 14 2008
    Tranny, Plugs and Fuel Filter Help
    I just figured i would try and keep the forum clean since ive been posting alot of threads latley for car latley and stick three subjects on one thread.
    1. Where can i buy a new fuel filter? Its never been replaced in over a year at least. If its dirty, will a new one improve my gas mileage?
    2. My tranny seems to be engaging roughly latley, when use the clutch it seems to grab abruptly. Even when i am in gear at a cruse, when i engage the clutch to the floor it seems to say 'i was happy where i was, i diddent want to leave'......i guess thats how i would describe it. lol. "Stubborn" could be another word to describe the way its acting. My buddy says its just because its FREEZING here and the clutch is just sticking a little bit. Its ushally in 10-20 degree weather outside at night here. Whats goin on in my tranny?
    3. Plugs - God only knows when the last time the plugs were changed. Ive only had the car for a year and have never done them. What should i use for my 1998 2.8L 30V Quattro Manual, in NY we get sub zero colds and blistering hots. I normally drive quite nice, many short trips, ushally 10-15min trips some 30-60min once and a while, with a few pedal to the medal moments here and there. (Idk what info is needed exactly )
    Thanks guys
    Black On Black 98' Audi A4 2.8L 30V 5spd. Quattro "Esabell"
    BBS RK's - Zimmerman - Vogtland Sports - Thrush Welded Cat-Back - DDM 6000 - Reigar RS4 - K&N Spectre - EbaySS - SpeedTuning Stage I
    Sep 23 2007
    Re: Tranny, Plugs and Fuel Filter Help
    For fuel filter it should go for 30,000 miles thats what i was told you should wait to replace it. I did mine and i instantly saw 60 or 70 miles per fill up i dont know if it was ever changed. You can pick one up at the dealer for $30 not to bad maybe $20 online, make sure you get all 4 crush washers or else you will get a leak.
    Sep 14 2008
    Thanks man, i would much rather pick it up somewhere then keep ordering things online, so maby thats what ill do. Maby Autozone or PepBoys will have them?
    May 16 2008
    WA
    i was wondering, why would a clogged fuel filter offer less mpg, is it because your car is not running as efficiently as it should? It would seem that the clog would cause it to run lean and use less fuel, but like i say i have read people say that many times and i am just trying to figure out why that is?
    Sep 14 2008
    bump?
    Junior Member Two Rings
    Jul 07 2008
    west haven, ct
    Just go to autozone.. They can look all that shit up.. Just don't buy a nonsense brand.. Get Bosch stuff and you'll be fine. It'll probably cost like $30.. Depending on the plugs.
    Sep 14 2008
    blowjustinup - you are talking all about plugs?
    Sep 23 2007
    I would not suggest autozone for a fuel filter simply because i picked on up there and it wasnt for my car, returned it and same thing. Try german autoparts or ecs, just make sure you get those 4 crush washers.
    Sep 14 2008
    ^ As in they kept giving you the wrong part? Or it just dident fit?
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Quote Originally Posted by getslideways View Post
    A clogged fuel filter can actually allow dirt through the filter and into your fuel system. Someone correct me if I'm wrong, but I'm guessing due to the impurities passing through, the car will run rich to make up for it.
    Sep 14 2008
    Would s sharp smell of gas coming from my car during start up signal running rich? Anyway, i should really find that fuel filter today. Anyone on my other questions?
    Sep 23 2007
    I dont think they carry it . The one that is right isnt bosch and its $30. You have to have it ordered. so i would just pick up the bosch at the dealer if i was you.
    Sep 14 2008
    Went to PepBoys, they looked in the computer and found a 'Purilater' or however its spelled, i used oil filters by them, no problems.
    Sep 14 2008
    bump?
    Sep 23 2007
    http://www.germanautoparts.com/Audi/A4/Fuel/92/5
    they ship fast i order and as soon as it leaves its here next day
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    i would just go to the dealer and get the oem fuel filter, its only like $30 and they will give you the 4 crush washers that you need. Very crucial. Fuel filter should increase smoothness in power band and prob fuel economy. I would wait though on replacing it. 30k is the earliest you want to change those out. I think any less and it would be kinda pointless, not to mention its kinda a PITA. For plugs, I would go with some normal Bosch plugs or some ngk's. I was given ngk BKUR6ET-10 (part #2397 i believe) plugs by a quality audi/vw shop. Havent gone in yet becuase im going to wait a little longer. But they seem like they will be good plugs, also for a 97 12v 2.8.
    clutches def act different dependent on weather, i would worry about it to much as long as you arent grinding or anything like that. Try pushing the clutch in quicker?
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Sep 14 2008
    Kronic, actually, i think it happens mostly when i do push the clutch in a little faster. It only does this every once and a while but it does bother me a little bit. Thanks for the Plug numbers. Why would you say wait on the fuel filter? I dont know when the last time it was changed. Ive only put 6,000miles on the car and shes at 112,000. Maby ill do the plugs and filter at the same time.
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    The clutch return issue is due to the cold brake fluid. It has been -10 to -25 with -52 or more wind chills here all week and my clutch pedal almost wouldn't return at all, the fluid is just too thick for the slave cylinder and has nothing to do with the tranny.
    Oct 01 2007
    1997 A4 2.8 QM
    oh ok well then it probably hasnt been replaced. I misread thinking that u said it was replaced recently.
    clutch issue prob has to do with the cold weather, im sure. And a slightly worn clutch.
    Sep 14 2008
    So whats wrong with my clutch? Is it going soon?
    Some more people chime in please, i have 2 totally different things being said about my clutch.
    Sep 14 2008
    bumpity?
    Jan 19 2008
    Quote Originally Posted by anmagro View Post
    You're fine. If when you start it up and it acts like you described, that's just normal for the cold like the others have said. If it were to continually do it even after you've driven the car for about 30 minutes, then I would be worried.
    Sep 14 2008
    Thats good to hear...well im just about to go on a 30min drive so i will check it out.
    Sep 14 2008
    well, i drove about an hour with 50/50 highway/city and i dident happen once. Thanks for the links guys. Ill be doing that filter/plugs come spring. Anymore sugestions for pulgs?
