Results 1 to 7 of 7
    Veteran Member Four Rings TurbousMaximus's Avatar
    Aug 25 2004
    Whitehall, PA
    No sound from all front speakers.
    Ok so my friend was in my car today and asked me if i have my sound faded to the back. I said no and showed him on the RNS-E it was in the middle.
    I faded it to the front and not a single speaker was working. I upgraded to an RNS-E from the sym. non-bose but cant recall if all the speakers worked before the install.
    Any input on what could be causing this? No sound at all from the front no tweeters nothing. But the back worked fine. I was looking for a fuse but couldnt find one for just front speakers. Thank you.
    2013 S7 Phantom Black on Black diamond - loaded
    2009 Audi R8, Black on Black w/ Blown V8 and black ADV.1 7.1's. (Carbon, Alcantara, Etc.) - Sold
    2011 S5 Sprint Blue w/ Silver Alcantara, B&O, Carbon Atlas, Nav, and Rear Differential - Traded.
    2006 A4 S-Line Brilliant Red 6spd - Sold
    2000 1.8tqms Ko4'd Brilliant Black - Sold
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    Re: No sound from all front speakers.
    The front speakers are powered straight from the RNS-E itself or at least should be. I would pull the RNS-E out and make sure that you have all the connectors hooked up and in the proper places. You can find wiring diagrams of it all on www.audiforum.us. If you search and can't find it let me know and I'll try to dig up the .pdf I saved a while ago.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    "Brown Chicken Brown Cow"
    Mods = 0
    Aug 25 2004
    Whitehall, PA
    Thanks a lot i started reading about that after posting this. I found this link.
    http://www.nsxjr.com/docs/RNStoSym2.pdf
    but in all honesty, i dont really no what im looking at lol. Im usually tech savy, but this has got me. Maybe ill show my brother, hes the electrical engineer.
    Mar 03 2008
    Washington
    You need to check connector II, which is the Symphony end. It should be the harness attached to your car.
    You will also need to check connector A which should be plugged into the RNS-E itself.
    Check to make sure you have that hooked up correctly.
    It might be possible that you incorrectly hooked up connector A on the RNS-E to connector III on the symphony instead of connector II as they have the same number of pins.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    Mods = 0
    Aug 25 2004
    Whitehall, PA
    Ok looking at the diagram and then my harness they look very different. I got mine from Euro-Parts.us. Mine only has 3 connectors coming off of it. A red and 2 blacks. My car is 2006 with non-bose and bluetooth.
    Aug 25 2004
    Whitehall, PA
    My harness only has 3 connectors. It seems like i don't have anything that plugs into the brown connector off the symphony end.
    Established Member Two Rings Fermo's Avatar
    Jan 26 2009
    06 Audi A4 2.0t fwd
    Houston
    I just bought a symphony II+ and ordered the harness from euro-parts.us and my front speakers don't work either. I emailed them tonight and hope they can figure this problem out quickly. I did notice that the sound was much better from the rears that worked. Hopefully they can just send me a new harness and it will work, it has to be a harness problem, I can't see it being anything else.
    2006 Liquid Blue Metallic A4 2.0T CVT
    APR Stage 1--H&R Sport Springs--19x8.5 Matte Black V710 VMR--Eagle GT 235/35's--ECS Tuning Smoke side markers and reflectors--ECS Tuning Blackout Grill--aFe Drop-in Panel Filter--Blue Lamin-X headlight/ foglight film--35% front, 15% Rear Window Tint--Silverstar Headlights & Foglights--Hawk front brake pads--Debadged--RS4 Rear Sway--APR Snub Mount-->In-Hand-->APR Test Pipe--BSH Catch Can
