Results 1 to 15 of 15
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    The best fluids for the s4 (tranny, diffs, rear ends, oil, all of it fellas)
    Whatdo you guys think? What do you guys praise by? Let them out
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Feb 17 2008
    Ottawa Ont.
    Re: The best fluids for the s4 (tranny, diffs, rear ends, oil, all of it fellas)
    There is no "best" there is only crap, and decent.
    Ill say this though:
    With the audi OEM trans fluid, I had breakdown and separation after only one season. Causing my third gear syncro to fail. Put either the audi high performance fluid in, or the motul, or redline synthetic in, and replace yearly if you drive hard.
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    Amsoil 75-90w Severe Gear Oil.... I live by it!
    Aug 06 2008
    Canadia
    redline 75W90 in the rear, center and front diff. wal mart tranny fluid for the tiptronic tranny.
    the rear diff takes a hair over 2 qt's, the centre is 1 qt and the front you'll be lucky to put in 1/2 qt and you have to siphon it out. i replaced the power steering fluid with CHF202 which is pentosin's latest and greatest and replacement for OEM CHF 11S.
    the B5 S4 is like the mafia... there is only one way out!
    Jun 14 2007
    2000 S4
    Connecticut
    My tranny fluid is Redline MT90 and my 101K tranny shifts like BUTTER. No exaggeration.
    Oil.. Castrol Syntec European Formula 0-30 for winter, Total/ELF 5-40 for summer
    Senior Member Three Rings AK1RA07's Avatar
    Dec 07 2007
    2001 S4, 1992 Miata, 1993 RX-7
    DFW
    I run Eneos 0W oil and Royal purple in the trans / diff.. although that will probably switch to Eneos as well at the next change.
    Jan 21 2007
    01.5 Silver Avant
    dc
    how hard is it to swap fluids and what not..i bought my car 2 weeks ago..and im trying to swap out all the fluids that i can do easily...so let me know which ones are easy to do... :-D
    Aug 06 2008
    Canadia
    Quote Originally Posted by casawhites4 View Post
    eveything requires you to put the car on a hoist or jackstands and monkey around underneath for awhile.
    engine oil is probably the easiest, front differential isn't very hard, but siphoning the fluid out is a bit of a pain, centre diff i had to unscrew an O2 sensor to get access to the drain plug, rear differential has the fill plug in a not to easy to access location.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    i use royal purple 75-90 in my transmission and i love it
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    May 22 2007
    East Bay, Ca
    Where do you access the front differential to change the fluid?
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Redline mt90 made a huge difference in how my trans shifted. It was so much smoother after i switched to it. I was running the Audi high performace stuff in it before and the shifts were very clunky.
    For oil i use Mobil1 0w-40 "European blend" and a Mann high capacity filter. I havent had to change the oil in any of the differentials yet, but when i do ill probably go with Redline gear oil. I dont think its better than Royal Purple, but it doesnt stink up your garage when you change it like Royal Purlpe does. That shit has an absolutely horrible smell that sticks to everything lol
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Jun 15 2007
    Quote Originally Posted by code7rpd View Post
    right by the front driver side axel
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Quote Originally Posted by SilverSurferS4 View Post
    x2 amsoil entire line is very good
    Aug 06 2008
    Canadia
    Quote Originally Posted by sCeRaXn View Post
    with royal purple your paying a premium for all their advertising on horsepower TV, etc and purple dye in the oil.
    Apr 13 2008
    Tennessee
    prefer ELF/Total over Mobil 1 and Amsoil for engine oil - have gone 9k, better to go 5k
    Motul Gear oil over Redline and Royal Purple - trans every 25k or so, rear diff *maybe* every 75k?
