Results 1 to 18 of 18
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    COLD! BT cold idle...
    Anybody else with BT have a touchy car when cold? For the first 30 sec or so after start up (it starts right up if I don't touch the gas), my car wants to stall if I touch the throttle . Is this normal? Its not a biggie really, but I have to blip the throttle a few times to get the revs up, and I sometimes stall trying to pull out of a parking space. Seems to only occur when its pretty cold out.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Re: COLD! BT cold idle...
    nope but I have only started the car in like 40s dont know if colder would be different
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    do you let it warm up for a few minutes?
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Yes ive had this same issue as well. But it could be related to my MAF. But once the car is up to operating temp It idles perfectly fine.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    -15F here now, the GTRS started well, but the idle is similar to what you stated, touchy for the first few secs. after it is fine, but I think it is a cold air thing and just a COLD!!! Thing. I hope it starts tomorrow AM!!
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Senior Member Two Rings gunde's Avatar
    Dec 07 2005
    Montreal
    I just posted elsewhere the same issue I'm having with my car. Even if I have a tiny K04.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    No problems with any of those symptoms here. My car runs fine in the cold. I don't move it until a minimum of after the high (1200rpm) idle.
    -Doug
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    I don't think it's a unique case with BTs. At those temperatures, fuel does not atomize properly, as a direct result is more resistant to ignition. So, imagine, your block trying to reach optimal temperature, and you start giving it some welly. You are Leaning out the mixture in an already less-than-optimal environment. Of course it's going to want to stall.
    Hold your panties, Give it a sec, and Don't be so eager to thrust.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    I concure
    Apr 12 2007
    Milwaukee
    my 1+ did the same, just have to let it run for a few seconds
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Having a test pipe affects cold starts. ECM adds a little extra fuel to try to heat up the cat quicker. No cat equals rich start.
    Jan 18 2007
    Lexington Ky
    hey Spinnetti where in Ky do you live? I am from Lex but work in Dayton Ohio as of right now. But i do come home on the weekends often.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    mine does it too, didn't want to go this morning in -1deg f., stalled twice before it "caught" the proper idle. Since going GTRS/Revo idle bounces for 30 seconds even when it's hot out, the stalling only happens if it's really cold out.
    Established Member Two Rings phsingl's Avatar
    May 03 2008
    2004 A4 Avant TQ-6MT
    NYC, NY & Springfield, VT
    +1 for the 'lumpy' start on very cold days (-17 today, yum) - but its no different than when I was stock.
    Like Doug says let it run without touching the gas for about 30 seconds until the idle has settled.
    Frankly its a good practice to let the engine sit running for awhile on any cold-start even in the warmer months to get all the fluids running round the internals.
    Dec 18 2007
    nj
    phsingl, what color is your car, it looks like a cross between silver and beige, guessing it's just the photos.
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by 400HPA4 View Post
    Ah, I think you hit it on the head..... I also noticed soot around the tail pipes... a bit over-rich looks like a good diagnosis.
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by KraftwerkB6 View Post
    I'm just south of cincy right off the 75/71 split towards Louisville.... Cruise 75 every day going to work.. I don't get on the road much on the weekends though as I'm spending most of my time on 3 different race cars I'm trying to get built up.
    May 03 2008
    Quote Originally Posted by widgget View Post
    Atlas gray - just the photos/lighting that may make it look a little off.
