Results 1 to 40 of 43
    Jun 08 2008
    Calgary AB Canada
    Aluminum trunk strip removal DIY
    After doing some searching, I found that most people said the bumper had to be off to remove the trim.
    Others had said that it could be done with the bumper on but the broke the little clips off.
    I decided to give it a go very lightly to see if i could get it out with the bumper on, and what do you know, it was really easy. didnt break any clips whatsoever either!
    To remove:
    Start by pulling the front side (closest to end of the car) up using your hands (i didnt need tools just yet) Work your way from one corner across to the other end.
    Once the first row of clips is out, you can go get a flathead or small chisel, wrap it in some cloth and work your way in under the strip.
    Lift the chisel upwards and allow it to press the bumper down and flex it so that the clip pops out, gently pull the strip away from the car work your way along each clip pulling each time you press the bumper down.
    It was hard to get a picture of whats going on inside, but heres what youre dealing with:
    Pulling as i go along
    Painting:
    Without sanding i got the plastidip out and gave it around 6 light coats. If i dont like the black I can always cut the paint open peal it off, or if i like it, ill keep it and hopefully it will hold up.
    I chose plastidip because it wont chip or scratch if i accidently hit it loading my trunk.
    Prior to sanding and painting, wash the piece really well. I used some laundry detergent to get the job done.
    I didnt sand incase i do decide to go back. If you want to get better adhesion, try sanding lightly with around 400 grit.
    Start your coats very lightly, dont try to cover all of the silver in one pass, youll end up having running paint.
    Take 10 minute breaks between painting, and be sure to paint the bottom aswell if youre using plastidip so that it doesnt peal off from underneath
    Finished product
    To pop it back on, just press it in slowly from one side to the other.
    Sorry that the pictures in the DIY are all with the painted trim, i didnt take any before.
    Enjoy
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Re: Aluminum trunk strip
    wow. definitely interested in how this turns out.
    it would be great if you could write up how to take the strip off.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    what color car do you have?
    i can't wait for the pictures of it back on the car
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    DIY!!! I want to do this!!
    02 A4 3.0Q6MT
    -chad
    Jun 08 2008
    Calgary AB Canada
    there really isnt much to pulling the strip off.
    Ill try to get pictures when i re-install it.
    My car is red.
    Deactivated Four Rings
    Apr 13 2008
    Bayern
    i'm a fan of the carbon fiber one
    Oct 07 2008
    East Texas
    hmmm...I have some CF wrap laying around, I could use it on this!
    02 A4 3.0Q6MT
    -chad
    Jun 08 2008
    Calgary AB Canada
    Re: Aluminum trunk strip removal DIY
    dumpdebump
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    I got mine color matched to my car. Looks way better since the car color does not get broken up anymore at that point...
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    Doing This Today On A Dolphin Grey
    Jun 08 2008
    Calgary AB Canada
    more pics.
    washed her ass
    then debadged
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    looks good with unpainted lowers
    Veteran Member Four Rings Undisputed's Avatar
    Jun 28 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Quote Originally Posted by Scrwedtxboy31 View Post
    Be sure to post pics. I have DG too and I'm curious to see how it'll come out.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    it looks really good with the unpainted lowers but i would still have to go with the carboin fiber one
    Senior Member Two Rings Peoples-2's Avatar
    Oct 24 2008
    Florida
    Quote Originally Posted by forevraudi View Post
    agreed, not sure how it would look on cars with painted lowers...there needs to be more black for it to look smooth
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    I did this a while ago on my dolphin grey. I like it a lot.
    Nov 23 2006
    "I'LL SHOW YE GARAGE!"
    Soooouuullllll Cal!
    Love it.
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    nice gonna try this on my silver a4 with unpainted lowers.
    Will match well with the blackout grills/ecodes. I tink!
    CT4952
    Oct 15 2006
    Arlington, VA
    Quote Originally Posted by Siggiepop View Post
    yea, next time the weather's a bit warmer, i'm gonna try this.
    Senior Member Three Rings Johnnada's Avatar
    Aug 02 2008
    04 Audi A4 3.0, 09 BMW 328 X-Drive
    MA
    Awesome work
    Senior Member Three Rings notob6's Avatar
    Nov 23 2006
    B6 a4 1.8t
    Chicago
    i did this a while ago to. its easier to do then blacking out the grille.
    Jun 28 2008
    Quote Originally Posted by Tony@Autobahn View Post
    Do you have any pics of it?
    -Damon-
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    I love that aluminum strip.... maybe because I have a black car?
    still, i'm not sure about the black out. seems like there is a gap from afar
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Jun 28 2008
    Yeah, it does. I do like it with unpainted lowers though. But that's not me so I don't know if it'll look good on my car.
    -Damon-
    Oct 07 2008
    East Texas
    Thanks for making a DIY! I'm going to be doing this soon!! BTW, It looks great on your car!
    02 A4 3.0Q6MT
    -chad
    Senior Member Three Rings 03CrysBlueB6's Avatar
    May 12 2008
    washington
    FOR ANYONE WHO WANTS TO KNOWWW!!! i did this about.. 6 months ago..and have gone through multiple brown bear car washes... i wash it normally with a brush.. it never peels.. hard raid or snow or anything.. holds up REAL well..looks good man!
    B5 A4 - silver [gone]
    B6 a4 - Crystal Blue [current]
    FS: B6 A4 sport struts with about 30k on them
    WTB: S4 or USP front
    Door Blades
    Rear Lip Spoiler
    USP or other Rear
    Dec 01 2007
    Orange County, NY 10918
    Now black out those rings. Looks like this:
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Jan 09 2009
    FL
    Would it be the same process with the b7 a4?
    Senior Member Three Rings Kengineer021.8's Avatar
    Sep 26 2006
    Whittier, CA
    Quote Originally Posted by Undisputed View Post
    I'd like to see this also, considering doing this on my DG
    Go: APR Stage 2, TT 225's, Forge 007 DV, STaSIS SS, RS4 Rear Sway, RaceTec FMIC, Forge TIP
    Show: 19" GM VMR 708's, Delsa S4 Spoiler, Blacked Out Grilles, Tint, Smoked Side Markers, De-Badged, RS4 Engine Cover, Aero Wipers, RNS-E, CC, Tinted Tails
    Senior Member Three Rings jeradw's Avatar
    Jul 18 2009
    2008 A4 (his) 2010 Tiguan (hers)
    Wisconsin
    Quote Originally Posted by Hyphy View Post
    x2
    Active Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    I did this 3 months back and painted it graphite gray to some what match my lowers, I Love is so far and had no issues removing it with a small pick..
    Gcc's blacksheep
    Senior Member Three Rings truls000's Avatar
    Feb 08 2010
    gone!
    Amazingly easy DIY, thanks man, one more thing to ad to my 'under construction list'...
    Veteran Member Three Rings doogie891's Avatar
    Apr 30 2009
    B8 Audi A4 2.0T Quattro
    Miami, Florida
    is there a part number for this piece??? mine broke on the left side because of stupidity and i cant seem to find anywhere that sells it! any help please!
    Veteran Member Four Rings b4a41point8t's Avatar
    Jun 06 2009
    Los Angeles, CA
    Paint ur lowers!
    Church, son!
    Active Member One Ring Zulu Kilo's Avatar
    Feb 24 2011
    Virginia beach, VA
    thanks for doin this DIY. i hve a bril red b6 an i was wondering how you take that peice off. didnt wanna break anything. looks great with black badges!
    Oct 12 2012
    Minnesota
    RE: Aluminum trunk strip removal DIY
    My trunk strip is missing most of the tabs on the outside, anyone know of a good way to child it down, since it is missing some tabs? It kind of pops up. I don't know about 3m adhesive tape in case I want to take it off again , might be kind of tough to take off.
    Apr 07 2011
    If you use 3M tape to put it on just use a heat gun and heat up the adhesive to take it back off.
    Senior Member Two Rings Slowaudi908's Avatar
    Apr 14 2014
    Audi A4 B6
    Doing this right now thank you for the diy :]
    Dec 19 2007
    York, PA
    uninstalling and re-installing on an S4 rear is a bit more intensive. the s4 bumper has the holes for clips, in certain spots, not in the same area....why? i dont know...kindve stupid. so you have to trim a few that dont line up to get it to fit on. just an fyi for future searchers.
    Apr 14 2014
    Audi A4 B6
    [IMG][/IMG]
    Came out great :]
