    Registered Member Two Rings RSMESS's Avatar
    Nov 12 2008
    01 TT Quattro (180)
    bel air, maryland
    weird humming sound
    after i turned my car off today i heard a weird humming sound that sounded like a fan was still goin. i had the key out of the ignition and i could still hear the sound. its coming from the side the turbo is on and it keeps coming on every few minutes. has anyone had a this happen?
    thanks
    just to add, it still hasnt stopped. its been humming for about 30 seconds to 1 minute and stopping for two or three minutes for the past hour.
    01 TT Quattro (180) Absolutely STOCK
    "Drive Safe"
    Jan 09 2008
    88'90quattro 98'passat quattro 05. Usp a4 571whp 97 a8 00 TT 99 Passat 2.8l 5 speed 99 Passat 1.8.
    haverstraw ny
    Re: weird humming sound
    you have a second fan on the right side it ia electric and is for when the car is running too hot or when the ac is on... check to see if it is the noise maker... then go from there....
    Nov 12 2008
    01 TT Quattro (180)
    bel air, maryland
    well i had it looked at and it was a fan needed for emmisions or something. the guy said i didnt need it so he just disconnected it.
    "Drive Safe"
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    you probably needed it. if it was for emissions then its probably the secondary air injection pump. not vital but helps
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Nov 12 2008
    01 TT Quattro (180)
    bel air, maryland
    Quote Originally Posted by zrowcool View Post
    what does it do and will i be ok without it until spring?
    "Drive Safe"
