Results 1 to 6 of 6
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    Weekend of modding
    Long weekend coming up with 4 days to do nothing so I've decided that I'm jealous of everyone with nice mods, and another DG B6 convinced me to debagde, so I'll be doing that first.
    Then, since I just got new tires (spur of the moment/emergency thing) getting a new set of wheels right now is out of the question soooo. Ill be painting my stock wheels something arounddd gunmetal. Ive read up on all the tuts and DIY's but are there an secret techniques or tips for these mods that might help me out this weekend?
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Jun 08 2008
    Calgary AB Canada
    Re: Weekend of modding
    take your time on the wheels. light coats. dont rush yourself, youll be happier in the end
    if youre not familiar with using spray paint, id suggest you try it on something other than your wheels to get the hang of it
    Veteran Member Three Rings Ultra B6's Avatar
    Sep 05 2007
    New Jersey
    my only tip for spraying the is to take long even strokes and hold the can about a foot away... also a easy way to paint fairly quick and make it look good is to do "flash coats" by going over the entire wheel once as evenly as possible, let that sit for 10 min then come back and repeat.. it will take a couple of times to get everything covered but from my experience you will get the best results
    if you want to speed up the drying you can also use a heat gun but if you have the time just let the paint dry on its own
    -James-
    04 Dolphin A4 USP CLUB MEMBER #84 3.0 QUATTRO TIP
    MODS:
    Pics:http://s231.photobucket.com/albums/ee167/ultrab6/
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    I've been wanting to do a group weekend mod session. I don't know if anyone has the space for it, but it might be fun. The only thing I have coming up is an Rs4 rear sway though.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    U mean a DIY day!!!
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Aug 03 2008
    Philadelphia, PA
    haha hit up the southeast forums and see if others are down for a DIY day. count me in!!
    -Kyle
