Results 1 to 24 of 24
    Established Member Two Rings banger2392t1's Avatar
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    Question HELP!! Air flow sound when im idled
    I was driving my car pretty hard yesterday and noticed when i slowed down i could hear what sounded like compressed air being released on the driver side. The noise goes away when i accelerate and only happens if i have had a long trip or been driving hard. I know it wasn't heater cuz it was turned off along with radio, so what is this noise??? Please help!!
    New s4 > Old A6
    2001 Silver b5 s4 250hp
    2004 Black Ski-doo MXZ 600 120hp
    2008 Red Sea-doo Super Charged RXP 255hp
    Fearless in winter
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: HELP!! Air flow sound when im idled
    Is the car boosting right? What is your vacuum at idle?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    I dont have a boost guage installed yet but one is in the hands of fed ex right now on its way to my house. Its seems im boosting alright other than the fact its quiet as hell and i can only hear the turbos when im going up a hill or in parking garage.
    New s4 > Old A6
    Fearless in winter
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    Common 70 views and no comments?
    New s4 > Old A6
    Fearless in winter
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I bet its your break booster hose. Do your brakes feel more stiff or harder to press? This is the hard plastic hose that goes into the firewall and the other end goes to intake under the Y pipe. Here is a pic of the hose:
    NOTE: it may look a little different depending if you have the 00 or 01
    Make sure its plugged in all the way into the firewall.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Also if it is a boost leak I wouldnt get on it too much until you fix the problem. That will be hard on your turbo's
    If it is your brake booster hose, you can buy one at genuineaudiparts.com They have it the cheapest for around 70 bucks. Also I can give you the part number.
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    I was going to suggest it may be the brake booster hose as well. I had that hose come off immediately after a WOT session. Needless to say, what felt like no brakes, a stalling car, and a loud hissing sound scared the crap out of me!!!
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    I looked at my brake booster hose and it seems to be fine and my brakes seem to work fine aswell. The rushing air sound comes now even if im at a low RPM at the stop sign and will stop when i start accelerating.But still only does it when the car is warmed up to a higher oil temp.im still cant figure out what it is and am driving my car as little as possible until i install my boost guage incase its the turbos, any help is appreciated!!
    New s4 > Old A6
    Fearless in winter
    Apr 18 2007
    ny
    You have to check all the braided vacuum lines, even a small leak can be loud.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    After second consideration i think that it might be my break boost hose because of the loud hissing noise of rushing air seems to be very prominant after i brake. When i release the break it hisses very loud than quites down afterward....My check engine light when one yesterday and im not sure if my brake boost hose would cause that or not??
    New s4 > Old A6
    Fearless in winter
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    If you are ever close to Etobicoke or Toronto, I could take a look at it for you.
    You need to do a pressure test though. All this online diagnosing is useless without a pressure test to truely find out where the air is escaping from.
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    If you need the part get it here:
    Pt # 078-133-701-AD sold at genuineaudiparts.com for $70.13
    I have a post about it here:
    http://www.audizine.com/forum/showth...=brake+booster
    Sep 19 2008
    Toronto, Canada
    Quote Originally Posted by gointoscott View Post
    Furthering (is that even a word?) on that topic, did you find out what the cure is for 00-01 owners?
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    with that off your car will idle pretty rough and you will only make like 6 psi with a giac chip. i did it one time it sucked
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    Another question is is my car alright to drive until i get it fixed, if infact it is the brake boost hose like i suspect? Im not driving it right now because im oviously worried it could do some serious damage, but i need a vehicle!! I have ordered a vag com today but it will take weeks to come from japan and i cant wait that long. How easy is it to replace brake boost hose, cuz im not a wrench.
    Oh and yeah it was idling pretty rough, along with the loud air rush sound.
    New s4 > Old A6
    Fearless in winter
    Oct 20 2008
    fuck off
    does it sound like you have some 272's in there?
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    Quote Originally Posted by sdoherty_tjm View Post
    272?????? Over my head
    New s4 > Old A6
    Fearless in winter
    Oct 20 2008
    fuck off
    does it sound like you have cams?
    does it sound like this?
    http://videos.streetfire.net/video/B...rev_150376.htm
    yes its a dsm but is that what it sounds like
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    My car doesn't sound like it has cams, the only difference i have really noticed is the sound it makes after i brake along with lack of power. I brought my car to my local mechanics today so he could taake a look at it for me and mybe give me some more insight. I hope its just the Brake boost cable and nothing serious or im fucked.
    New s4 > Old A6
    Fearless in winter
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    I just talked to my local mechanic and he said it would cost around a woping $800. He said it is about 3-4 hours of labour and about 4-5 hours for the part...Is my mechanic making me grab my ancles or is this a normal price
    BTW (CAN) dollars
    New s4 > Old A6
    Fearless in winter
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    I just looked up the price for a brake booster and the price is an unfortunate $419, so i dont know where $70.13 came from.
    I guess the $70 is for just the hose and apparently the wrench said my whole brake boost unit is garbage so the $419 is normal. I guess im just fucked and have to cough up the dough!!
    New s4 > Old A6
    Fearless in winter
    Sep 19 2008
    Toronto, Canada
    How did he prove it was the actual brake booster unit and NOT just the hose which is the common problem with these cars?
    I think it's 2nd opinion time.
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Quote Originally Posted by banger2392t1 View Post
    Yes the 70 dollar part is just for the brake booster hose. I would also like to know why he thinks its the brake booster itself and not just the hose.
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    I still have my brakes and the air whistling noise was only happenin when i released the brake and not all the time, which he said it would if the hose came off. I told him about the boost hose thats frequently comes off on our car and he said he checked that and it wasn't it and that if the hose had come off i would have had no brakes, which i did....still not sure what to do and waiting for more feedback.
    New s4 > Old A6
    Fearless in winter
