This is how I mounted the bulb, this is my way. I'm sure there are others, but I found this to be the most effective.
I found those metal clips at my work, we use them for our lasers so I would have no idea where to actually get them.
For the igniters, I took the stock bulb harness, removed the circle trim (the "lock") which is colored in purple in the picture and plugged the wires into the harness. You could also splice into the wires directly, but I wanted the option to remove the HID kit If I wanted to.
Enjoy:
