Results 1 to 12 of 12
Thread: MBC on B5
    Sep 04 2008
    p
    MBC on B5
    After installing a MBC, FMIC, and Forged wastegate.. the car only spikes 8psi on first until 3k rpms then holds 5psi only and in the next gears the car only holds 5psi. The MBC is connected directly to the wastegate and turbo hoses. N75 is in place but without any hoses. If i turn boost a little higher the car gets a sort of limp mode. ANYONE HAS DONE THIS BEFORE?
    How much should it boost stock?
    Thanks
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: MBC on B5
    What year is your car?
    Sep 04 2008
    p
    Re: MBC on B5
    its a friends and its 96
    Dec 05 2007
    Re: MBC on B5
    Sounds just about normal for a stock ECU and all those components really were not needed if the car is planning on staying stock. I have a flashed ECU and the only thing I have upgraded was the dv. But I don't go around driving like a mad man
    AEB is 7psi peak stock
    ATW and AWM is 11psi peak stock
    Jul 07 2004
    socal
    Re: MBC on B5
    Actually the ATW was also 7psi stock like the AEB. Audi did not bump the boost up to 11-12psi till 2001 with the AWM. This is why the AEB/ATW were 150hp stock and the 2001 was 170hp stock.
    Sep 04 2008
    p
    Re: MBC on B5
    Well its a long story about why he got those components....
    Thing is that the car is running stock boost (7psi), and because the FMIC hes losing 2psi filling it, right?
    Now how can you make this car to run more boost on a stock ecu???
    Someone here must have done it.
    Example in the DBW cars you can use a diode on the map to run more than 11psi..
    What can you do in this case?
    Dec 05 2007
    Re: MBC on B5
    Get a chip
    Sep 04 2008
    p
    Re: MBC on B5
    If you tell me who will make it for a eurospec car, ill look at it.
    Giac and uni dont make it
    Dec 05 2007
    Re: MBC on B5
    May want to check into Upsolute. http://www.upsolute.com/index.php. They have a lot of different chips for the B5 A4.
    Jul 07 2004
    socal
    Re: MBC on B5
    Quote Originally Posted by msr1 View Post
    GIAC has dealers world wide, believe me they have a chip for the eurospec cars.
    Sep 04 2008
    p
    Re: MBC on B5
    For the B6 they didnt had.. so my ecu stayed in Giac for 8 weeks.. i called them and they said they wouldnt make it for the B5..
    Jul 07 2004
    socal
    Re: MBC on B5
    Must be that your ecu is one that they will not do. Because Lucas is/was a GIAC dealer in Australia and he sells GIAC tunes for the B5.
