Results 1 to 16 of 16
    Established Member Two Rings JD3's Avatar
    Dec 31 2008
    E92 M3
    Columbus OH
    32 offset on a B6 S4?
    Anyone out there running a 32 offset? I know it works on a B5, but not sure about a B6. Also, as a tech question, I understand what offset is, but which wheel would have a deeper lip, a 35 offset or a 45 offset? One more quickie, what does the "et" stand for when talking about offset. I often see 35et offset, what's the "et"?
    Thanks for the help!!!!
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    Re: 32 offset on a B6 S4?
    Dunno. Also how wide is the rim? Check out this post.. http://www.audizine.com/forum/showpo...6&postcount=22
    Its my understanding that offset has nothing to do w/ lip size. Lips on a 35 and a 45 can be the same depending upon the construction of the rim and how the spokes come off of the center portion of the rim. The offset is just going to push or pull in how flush the tire is w/ the wheel well. If i am wrong someone please correct me.
    I remember reading a while back that it was a german word that translated to insertion depth..
    Edit: here you go
    "The offset is described by the term ET, which is from the German word 'Einpresstiefe' translated as 'insertion depth'. Most wheels have a positive offset which means the mounting surface is further outboard than the wheels centre. If you reduce the amount of positive ET on the wheel the the vehicles track is widened and vice versa if the ET number is reduced. Straying too far from the original offset can be detremental as fouling to the suspension and bodywork can occur as well as eccess strain on wheel bolts or studs"
    Registered Member Three Rings Buegie's Avatar
    Sep 18 2007
    e90
    Quote Originally Posted by JD3 View Post
    as mentioned, the lip size has nothing to do with the offset, but I think what you're getting at is which one which one will poke more...a et35 will poke more than a et45. And I don't really understand that link above, how can you say et32 is the most aggressive possible without knowing the width? Plus thats just an opinion anyway, some people like more poke than others
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Quote Originally Posted by Buegie View Post
    people in this forum are scared of poking like it's aids
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Veteran Member Four Rings ItzDarrellS4's Avatar
    Jul 14 2007
    A Sedan, a Hatch, a SUV, and a Pickup
    The Live Free or Die
    Im running 19x8.5 32et. rubs sometimes over bumps if the wheel is turned
    mpg's lol
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    Quote Originally Posted by ItzDarrellS4 View Post
    i like your wheels!
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Senior Member Three Rings Rodknock's Avatar
    Jun 25 2008
    The Dirty T, WA
    I have some 18x8 RX's that are et32 and they fit just inside the fender..
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    19x8.5 ET32 and approx 25.5 ground to fender all around and no rubbing.
    Senior Member Two Rings 1.9TDI's Avatar
    Mar 03 2008
    Nogaro Blue B6 S4 6MT, Quartz Grey B7 A4 Quattro
    Orlando, FL
    Just put on some 19x9 et24 on the rear of my s4, no rubbing but I have a little bit of tire stretch to clear it
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by 1.9TDI View Post
    Id like to see this. Pics or it didn't happen.
    Mar 03 2008
    Orlando, FL
    Quote Originally Posted by MOFSTEEL View Post
    Ha, I'll take pics as soon as I can, I put them on the car last night and in the process, my jack failed, resulting in my S4 falling on my hand....Not really in the mood to take pics at the moment, but I will soon
    Sep 18 2007
    e90
    Quote Originally Posted by 40valve View Post
    I guess so
    Dec 31 2008
    E92 M3
    Columbus OH
    Yes, which would poke more is a better way to put it. So it sounds like a 32 offset would be okay on a 2004 S4. It's lowered but only about .25. Thanks everyone for the assistance.
    Dec 31 2008
    E92 M3
    Columbus OH
    19" x 8.5" wide btw.
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    I like the look, very clean! Nicely done!
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Oct 03 2008
    Atlanta BITCHES!!!
    Quote Originally Posted by mbgt72 View Post
    Inb4mosteelsaysitsforsale
