Results 1 to 13 of 13
    Mar 27 2008
    Denver
    awe pedals just installed.
    Really happy with the way they turned out they don't look ricey at all also they match my silver trim pretty well. I'll post another picture when its sunny out all the other ones turned out blurry I took in the parking garage.
    Saint Cloud, Fl
    Re: awe pedals just installed.
    nice addition
    instagram ------------> low_enforcement
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    how hard was the install? what was involved.. do they clamp or do you drill and through bolt?
    Mar 27 2008
    Denver
    I had a local shop install them (Avalon Motorsport), they said they had to order a bit for it. You just pop off the rubber caps on the pedals and bolt these ones to the existing metal. I did not want them to be crooked so I just had someone else do it, was only 45$ though he said they should have charged me for an hour (90$) he had already quoted me at the 45$ I would recommend them to anyone who's looking to get new pedals they make heel-toe a little nicer too.
    Senior Member Three Rings riot5alex's Avatar
    Jan 25 2008
    03 3.0QM
    Illvine, CA
    wait.. you paid someone 45 bucks to install your pedals?
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Hey I didnt authorize you to take pics of my pedals. JK I installed these very same pedals a few days ago and I meant to take pics. I was actually in PA and i drove to AWE and purchased a vagcom along with gunmental pedals. As long as youve got the correct tap sizes and drill bits its an easy install. Took me an hr to do outside in the cold.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Quote Originally Posted by riot5alex View Post
    Honestly $45 to do that isnt a bad deal... they are quite a headache to install if you don't have an angled drill. I found it very helpful to remove the lower dash bolster so that there is more room because I was using a normal hand drill and you cannot get it perpendicular to the pedal when drilling without removing that... which makes the bit slip around even if you've used a center punch to mark the spot.
    The little rubber things fall out... I used to keep them in the door but gave up. Soon enough your pedals won't be so shiny and new anymore, they'll look like this! (its hard to see but they are pretty beat up after ~40,000 miles of use)
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    I have the AWE gunmetal pedals. They were a bit of a pain to install - ended up having to buy a better tap because my harbor freight one couldn't get through the metal brake pedal. The plastic clutch and accelerator pedals were easy.
    I glued my rubber nubs in place before installing - I think that was recommended in the instructions.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Sorry, but I would be embarassed to ask someone to install pedals on my car, lol
    They do look good though. I would be worried that my shoes would slip off (if it was wet/raining)
    -Sami-
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    I am going to get RPI to install mine. Thing is, you need a Standard 10/32 Tap and most european car shops use Metric.
    I'm not sure why AWE decided to use Standard...
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    May 03 2008
    Orlando
    Quote Originally Posted by BNZ TOY View Post
    Home Depot sells a package with a 10/32 tap and drill bit for around 6 bucks. If you have that and a drill you won't have any problems. Just remove the panel under the steering wheel.
    Kevin W.
    Apr 20 2007
    Lander, Wyoming
    This irked me as well but I think they decided to use and SAE thread because individual metric taps are hard to find, while individual SAE taps are cheap and plentiful.
    Jon
    go > show
    Ich liebe mein Audi
    Veteran Member Three Rings Euro's Avatar
    Sep 18 2006
    Bimmers
    Portland
    They look great Jace.
