Results 1 to 28 of 28
    Veteran Member Three Rings b5power's Avatar
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Oil around Sparkplugs...Please Help (pictures) UPDATED:1/23/09
    im having problems with my 98 AUDI A4 AEB TIPTRONIC with about 140000Miles. I have a blinking CEL and i replaced all four coilpacks (meyle) and sparkplugs just yesterday and i thought it would remove the CEL ,but i still have the blinking CEL. By the way when i removed the old sparkplugs there was oil on sparkplug #1,3,4. here are some photos below. This Saturday I will replace my cat converter ( i already replaced both of the o2 sensors)and fuel filter (havent change it since i got the car which was about 1.5 years ago)...hopefully that will help.
    here are the codes i got from autozone.
    P1300
    P0422
    PO203
    Any suggestions? thanks
    euroBREED
    ASP Stage 3
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    Re: Oil around Sparkplugs...Please Help (pictures)
    what do the new plugs look like? are the same 3 fouled already?
    Feb 27 2005
    North Wales, PA
    Is that clean plug from cylinder 3? Check that injector connector. Clear the codes and report back. Did you change your ignition control module?
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Quote Originally Posted by Poopie View Post
    That clean plug is fr cylinder two. And I change my ICM about less than 5000 miles ago...
    euroBREED
    ASP Stage 3
    Dec 04 2007
    New York, NY
    maybe your spark plug seals are going / gone?
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    Quote Originally Posted by flyromeo3 View Post
    spark plug seal?!!? really? like mentioned check the injector on cyl #2. the plugs dont look that bad for being used. however one clean one is not right,
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Well, if you've got oil on the ceramic parts of the spark plugs, then you'll need new valve cover gaskets.
    If the oil is below the "nut", then you've got some internal leaks causing oil to get into the combustion chamber.
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Quote Originally Posted by Mike@PureMS View Post
    I already changed my valve gasket about 3000 miles ago, so im guessin its internal...which is not good! by the way whats an average price to replace the head gasket or whatever?
    euroBREED
    ASP Stage 3
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Quote Originally Posted by JaVa View Post
    ill check injector #2 this weekend, but if so how i do i clean it i already used injector cleaner less than 100 miles ago...you think i should replace it with a new one?
    euroBREED
    ASP Stage 3
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    X2 valve cover gasket. Easy fix
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Quote Originally Posted by biketsai View Post
    but i just replaced it about 3000 miles ago. should i replace it again?
    euroBREED
    ASP Stage 3
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Quote Originally Posted by b5power View Post
    i guess it wudn't hurt to check. when mine went, i didn't have nearly as much oil on my plugs as you do.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Feb 27 2005
    North Wales, PA
    its not the valve cover gasket. there would be oil on the ceramics of the plugs. That plug looks brand new. If the cylinder was firing that electrode would have turned greyish. Check the coil packs again and the ICM as well as the injector connector and the injector itself.
    Nov 03 2008
    98A41.8TQM
    yea its not the VC gasket. if the white ceramic part of the plugs were black, it would be this gasket. its obviously not that. are you sure that its oil and not just unburned fuel?
    Feb 27 2005
    North Wales, PA
    P0203 - bad injector, connector, or circuit
    P0422 - Main catalyst effinciency below threshold (bank 1)....probably from running rich
    P1300 - random misfires....probably due to the injector not spraying fuel. Swap in new plugs and move that cylinder 2 injector and see if that clean plug follows it. If it doesn't then check the injector wiring.
    Dec 04 2007
    New York, NY
    Well do you have a better opinion vs reiterating what we see in the picture?
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Your ICM is bad again. Swap it with a good one and recheck.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    bump
    euroBREED
    ASP Stage 3
    Established Member Two Rings Tigu's Avatar
    Sep 05 2008
    a4 MK1, Octavia II
    Hellinn Talsinki
    so whats the situation`??
    it really seems that bad is something with the fuel mixture.
    meaning pull out the injector on that cilinder and check it.
    also the ICM... but if it's said to be new already, hmm. sounds more like the injector.
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    how do you check if the injector is bad or not when i take it out
    euroBREED
    ASP Stage 3
    Feb 27 2005
    North Wales, PA
    swap the injector somewhere else. and see if that clean plug moves with the injector.
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    why would 1 injector make 3 plugs foul? is the misfire/flashing cel fixed yet? if not, you should check your faults before you start pulling parts.
    as far as testing/inspecting the injectors, you can get some glass or sturdy plastic cups, pull the whole rail with injectors attached, put a cup on each injector, and crank the engine, to compare the amount of fuel flow from each injector. a noid light can be used to check duty cycles, but you really need to hook it up to a vag-com before getting into the heavy technical aspect.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    update:
    i switched around injector #3 with #4 to see if inj.#4 would spit out fuel...after running the car for about 15 minutes...inj. #4 did not do anything...so im guessing its not the injectors, its a circuit/wire harness and maybe the icm...what do you guys think?
    euroBREED
    ASP Stage 3
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Have you cleaned the PCV system, or replaced the valve anytime in the last 10-11Y? The B6 is notorious for this (so I wonder about the B5), and dumps oil under the cover all over the coil packs, plugs, and harnesses, causing misfires. Fix the PCV system while you're at it.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Update:
    Purchased HUCO ICM from Ecstuning...and it got rid of the blinking CEL! yay! haha, unfortunately i still have a CEL...here are the codes
    P1300
    P1545
    P0301
    P0300
    P0422
    Oh so far i got new Coilpacks, new plugs gapped at 28, new ICM, new fuel filter, new o2 sensors top and buttom(less than 300 miles on em)....Any suggestions?
    euroBREED
    ASP Stage 3
    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    yeah doesn't hurt to change the gasket again even if you did it recently you might of not torqued it down all the way
    Feb 27 2005
    North Wales, PA
    Update:
    P1300
    P1545
    P0301
    P0300
    P0422
    is that after you cleared the codes?
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Yea
    euroBREED
    ASP Stage 3
