    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Damn thing wont start ...
    So I left my car with my body shop while I was out of town last week and when I returned today it was doa.
    Apparently after I left it started when they moved it in and out of the shop but a couple of times it stuttered and ran rough. Shop manager said there was a flashing CEL and it sounded like it was on 3 of 4 cylinders. Then after a couple of the rough starts it stopped starting all together. It turns over, theres fuel in the tank and in the rail but it wont start.
    I thought "coil pack" for sure ! But when I got the 2 new "R" coils delivered and returned with a vagcom it got wierd ... the vag connects to the ECU but reports no codes So I swap coil packs randomly and pull #2 and 3, no start. Then I do some more random swapping with no luck and eventually call a flatbed to take 'er to Audi ... I am out of ideas
    Nice way to return from vacation !
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Re: Damn thing wont start ...
    did you check the pl;ugs and the battery, may have been flooded and fouled up the plugs, or the batt is too low and too many short starts ended up killing an almost dead battery. Just a few ideas.
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Sep 01 2004
    Vancouver Canada
    We did charge the battery so thats not it. The plugs are at the top of the list for tomorow.
    The really odd thing is that there has been a persistent code present all the time in the ECU and that code wasnt present today. Other than with an ODB tool what could erase all the codes in the ECU ? If the car ran that bad last week then there must be a fault code thrown somewhere to give a hint ? no ?
    Senior Member Two Rings Eyerate's Avatar
    Aug 19 2007
    CP problem- check again
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    unplug the MAF (mass air flow sensor) and see if it starts. also just because you have fuel in the rail does not mean that it is at the correct pressure... could be a dying fuel pump as well.
