Results 1 to 3 of 3
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    * Need Help Asap!!
    I just got my ecu back from getting chipped and it won't run anymore. I put the ecu back into the car and i took it around the block. Pretty good improvement but when i got in front of my house it just died.
    The symptoms: The car made a high pitched noise not like the regular sound i used to hear from the splitter. I tried to start it up to pull it into the driveway, it starts and then rpms drop and die right away. i replaced the coilpacks but the car just starts and dies instantly and has no CEL but a battery symbol. If i try to gas it to keep the car on the high pitch noise whistles and you can smell a lot of fuel.
    im thinking it might be the fuel pump can't think of anything else.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    Re: * Need Help Asap!!
    test the fuel pump , don't start the car but turn on the ignition. and press on the gas pedal that should dump some gas and you should be able to smell the gas through your exhaust.
    i've heard when the fuel pump dies or is on the way out it makes a high pitched whirring noise , is the noise coming from where the fuel pump should be?
    did you make sure the ECU was seated in properly.
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    hey Kev there was a factory recall on 03 fuel pumps...your dealer may change it for free...
    which software did u go with?
    another stereotypical Audi
